Hydraulic Clutch Reservoir, What did you use, and how did you mount it |
Mowog4 |
Feb 4 2018, 10:55 AM
Member Group: Members Posts: 291 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I am hoping someone can point me in the direction of where they mounted a clutch master cylinder reservoir. I know I have seen it before but have been U.N. able to find it. Please help,
Thanks Ed |
effutuo101 |
Feb 4 2018, 01:12 PM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
I don’t have any of the heater stuff. I used a Tilton 3 reservoir to handle front, rear and clutch.
Attached thumbnail(s) |
914forme |
Feb 7 2018, 03:01 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
I don’t have any of the heater stuff. I used a Tilton 3 reservoir to handle front, rear and clutch. That Tilton three chamber is what I used and Scott is using on PORSTI and Grey Matter Builds, solves the issue with the other stuff that leaks at the bottom. You can get it with press on fittings or AN fittings. It will fit with the heater stuff in place, you just have to build the mount. Somewhere in the build thread I have one made up. A little (IMG:style_emoticons/default/smash.gif) in a vice I need a Magna Brake Make my stuff look so much better |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:06 AM |
