Seat Belt Question, tension creates tension |
Millerwelds |
Feb 7 2018, 01:02 PM
Pleepleus Group: Members Posts: 715 Joined: 24-June 08 From: Grass Valley, CA Member No.: 9,206 Region Association: Northern California |
I have had my 914 for 7 or 8 yeas now. Lately the seat belt has been retracting so well that it is cutting into my neck while driving (at least it feels that way). I do not recall it ever being an issue before. I recall you used to be able to slightly tug on a tight belt and get it to lock into a slightly loose position so it was comfortable. This belt is not doing that. It does not appear that the passenger belt does that either. Is that feature built into the 914 belts? Would removing and soaking / relubing the mechanism get that feature to start working again? Car is a 74 by the way.
mgphoto |
Feb 7 2018, 03:46 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I have had my 914 for 7 or 8 yeas now. Lately the seat belt has been retracting so well that it is cutting into my neck while driving (at least it feels that way). I do not recall it ever being an issue before. I recall you used to be able to slightly tug on a tight belt and get it to lock into a slightly loose position so it was comfortable. This belt is not doing that. It does not appear that the passenger belt does that either. Is that feature built into the 914 belts? Would removing and soaking / relubing the mechanism get that feature to start working again? Car is a 74 by the way. They don't work that way. The belts come with a small plastic clip that prevents the belt from retracting . |
Millerwelds |
Feb 7 2018, 03:49 PM
I have had my 914 for 7 or 8 yeas now. Lately the seat belt has been retracting so well that it is cutting into my neck while driving (at least it feels that way). I do not recall it ever being an issue before. I recall you used to be able to slightly tug on a tight belt and get it to lock into a slightly loose position so it was comfortable. This belt is not doing that. It does not appear that the passenger belt does that either. Is that feature built into the 914 belts? Would removing and soaking / relubing the mechanism get that feature to start working again? Car is a 74 by the way. They don't work that way. The belts come with a small plastic clip that prevents the belt from retracting . Thanks. Amazon seat belt stoppers it is! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:13 AM |
