Oh no! Lost oil pressure ... |
SirAndy |
Feb 15 2018, 08:38 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Got stuck in traffic on my way home from work today and didn't notice the oil light until the engine started making horrible noise.
Did the only thing i could think of which was to pull onto the side strip and get on the gas hoping to get oil pressure back. That actually worked! Pressure went back up to ~80 under load and ~30 at idle for the rest of the drive home but i'm afraid i might have done some permanent damage. By the time i noticed the engine noise and the pressure being at zero i was probably already running completely dry. (IMG:style_emoticons/default/headbang.gif) Now the real question is, how the heck did that happen? I checked the oil after i got home and it's still all in there. All 16 quarts of it. Could there be a blockage somewhere? Stuck piston? Clogged filter? (IMG:style_emoticons/default/sad.gif) |
Dave_Darling |
Feb 16 2018, 10:04 AM
You're just guessing until you start examining stuff. The first step is to open up the oil filter and see if there is any metal trapped in it.
--DD |
SirAndy |
Feb 16 2018, 11:05 AM
You're just guessing But that was sort of the point of this thread, i want people to guess so i can cover more possibilities. There are many people on here that know a lot more about /6 engines than i do ... (IMG:style_emoticons/default/shades.gif) |
mepstein |
Feb 16 2018, 11:18 AM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You're just guessing But that was sort of the point of this thread, i want people to guess so i can cover more possibilities. There are many people on here that know a lot more about /6 engines than i do ... (IMG:style_emoticons/default/shades.gif) See post #2. It can be a lot of things but the oil filter will tell you a lot with very little effort. If you see gold, you will know to pull the engine for a rebuild. No other search needed. If the oil looks clean, then step 2. |
Tdskip |
Feb 17 2018, 09:38 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
QUOTE See post #2. It can be a lot of things but the oil filter will tell you a lot with very little effort. If you see gold, you will know to pull the engine for a rebuild. No other search needed. If the oil looks clean, then step 2. I think this is really good advice. Having had a similar experience there's a risk of chasing anything and everything without getting to ground truth. Getting a lab to let you know what's in the oil is also a really good idea I think. My fingers and toes are crossed for you that that the filter is clean. |
Lo-Fi Version | Time is now: 11th June 2024 - 02:02 AM |
