| lonewolfe |
Feb 3 2018, 07:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Are any of you running a retun fuel line with carbs?
| rhodyguy |
Feb 21 2018, 12:53 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Get the self regulated carter pump. Keep it simple. Put the return line in the tunnel while you're in there so it's ready if you go back to fi. Cap both ends, the return spigot on the tank and leave it alone. Single supply to a Tee in the engine compartment. One line to each carb. Keep the carb lines off of the engine tin. Stock phenolic spacers under the intakes help with the heat. Some expensive hp pump, a gauge and regulator?
lonewolfe Return fuel line with carbs? Feb 3 2018, 07:06 PM
struckn I'm not running a return line...actually I had... Feb 3 2018, 08:38 PM
brant Yes.
A return fuel line in s a good thing.
Kee... Feb 3 2018, 08:51 PM
Larmo63 On a six with Webers, I'm not sure how it work... Feb 3 2018, 09:05 PM
jcambo7
On a six with Webers, I'm nt sure how it work... Feb 3 2018, 09:45 PM
porschetub
On a six with Webers, I'm nt sure how it work... Feb 3 2018, 11:11 PM
mmascari
On a six with Webers, I'm nt sure how it wor... Feb 3 2018, 11:17 PM
brant
On a six with Webers, I'm not sure how it wor... Feb 4 2018, 08:19 AM
Krieger To be clear the rectangle is the filter. Circle i... Feb 4 2018, 10:59 PM
brant
To be clear the rectangle is the filter. Circle ... Feb 5 2018, 12:37 PM
gothspeed I like option E with double barb banjos on the car... Feb 5 2018, 12:21 AM
bbrock
I like option E with double barb banjos on the ca... Feb 5 2018, 08:27 AM
gothspeed
I like option E with double barb banjos on the c... Feb 5 2018, 08:42 AM
Racer Chris
I like option E with double barb banjos on the c... Feb 5 2018, 08:46 AM
bbrock
[quote name='bbrock' post='2575289' date='Feb 5 2... Feb 5 2018, 10:22 AM
lonewolfe I have Dellorto carbs so one has the menu intake l... Feb 5 2018, 12:41 AM
anderssj I've been running dual dell's with an ... Feb 5 2018, 09:48 AM
Socalandy covered here, im running tangerine lines with PMO ... Feb 5 2018, 09:54 PM
North Coast Jim No return line in use with 44 IDFs. Car runs great... Feb 6 2018, 08:09 AM
1adam12 What's up guys! I just purchased a pair o... Feb 21 2018, 11:03 AM
bbrock
What's up guys! I just purchased a pair ... Feb 21 2018, 01:48 PM
1adam12
Get the self regulated carter pump. Keep it simpl... Feb 21 2018, 03:55 PM
rgolia Not sure I get the return line need/benefit with c... Feb 21 2018, 02:56 PM
bbrock This is just from what I've read on the Intern... Feb 21 2018, 03:28 PM
1adam12 Thanks
rhodyguy
bbrock
rgolia
For the input. I g... Feb 21 2018, 03:41 PM
brant also...
I've run many a rotary or low pressur... Feb 21 2018, 04:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th May 2026 - 08:12 AM |
