Window adjustment, Can this gap be closed ? |
jim_hoyland |
Feb 28 2018, 05:28 PM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
There is a 3/8” gap between the front edge of the glass and the targa top rubber seal.
Car is a ‘75 Can the the glass be adjusted to close this gap ? How. Attached thumbnail(s) |
mgphoto |
Feb 28 2018, 07:32 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
There is a 3/8” gap between the front edge of the glass and the targa top rubber seal. Car is a ‘75 Can the the glass be adjusted to close this gap ? How. Hey Jim, There is a window height adjustment on the underside of the door toward the front. There should be a slotted screw in the middle of a 8mm locknut (13mm wrench). Undo the locknut and turn the screw until the window closes correctly. I have the early doors which have the cable lifters, but the later doors function the same even with the later scissor lift mechanism. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:02 AM |
