Steel flares, How many hours? |
sb914 |
Feb 28 2018, 08:26 AM
Surf Guru Group: Members Posts: 4,315 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Steel flares !! So for those of you who have done this, how many hours would a shop typically take ready for paint ?
tygaboy |
Feb 28 2018, 08:37 AM
914 Guru Group: Members Posts: 5,308 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I'm about to start on mine. Maybe I should time it!
Cracker |
Feb 28 2018, 08:49 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Chris - That would be 24-hours PER corner for you...you will install and replace each corner at least two-times due to a hair-like flaw in the weld! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif)
T I'm about to start on mine. Maybe I should time it! |
Mueller |
Feb 28 2018, 10:33 PM
Chris - That would be 24-hours PER corner for you...you will install and replace each corner at least two-times due to a hair-like flaw in the weld! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) T I'm about to start on mine. Maybe I should time it! ^ditto, there is no way those flares are being installed as-is. They will be trimmed, stretched/shrank and spend some time on the English wheel for sure. |
KELTY360 |
Feb 28 2018, 11:11 PM
914 Neferati Group: Members Posts: 5,036 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Chris - That would be 24-hours PER corner for you...you will install and replace each corner at least two-times due to a hair-like flaw in the weld! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) T I'm about to start on mine. Maybe I should time it! ^ditto, there is no way those flares are being installed as-is. They will be trimmed, stretched/shrank and spend some time on the English wheel for sure. Wait, you mean he's not making them from a flat sheet of steel? |
Mueller |
Feb 28 2018, 11:29 PM
Chris - That would be 24-hours PER corner for you...you will install and replace each corner at least two-times due to a hair-like flaw in the weld! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) T I'm about to start on mine. Maybe I should time it! ^ditto, there is no way those flares are being installed as-is. They will be trimmed, stretched/shrank and spend some time on the English wheel for sure. Wait, you mean he's not making them from a flat sheet of steel? Shocking huh? I think I might have accidentally kicked one of them last time I was there, I'm sure that'll warrant a change of plans for sure. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:11 AM |
