> 914 race suspension front A arms, Do you know a source of 962 style lower A arms, see pic.
bryans914
post Mar 2 2018, 03:12 PM
(IMG:style_emoticons/default/WTF.gif)
Need source for 962 style lower A arm for coil over on 914-6. I attached a pic.
Need to replace 8 ea 16" Fuchs/barrels with 18" inexpensive steel or mixed material race wheels. The Fuchs are breaking with 450/500bhp. Sources?
jd74914
post Mar 3 2018, 01:21 PM
Its alive
Do you have a better picture of that control arm? It looks pretty easy to fabricate from scratch...
bryans914
post Mar 3 2018, 01:39 PM
QUOTE(jd74914 @ Mar 3 2018, 11:21 AM) *
I have the trans out, working on rear swing arm, so will remove front A arm and steering rack next. Thanks.
bryans914   914 race suspension front A arms   Mar 2 2018, 03:12 PM
burton73   Are you Fuchs real or copies? Fuchs are used on Tu...   Mar 2 2018, 03:41 PM
mepstein   Are you Fuchs real or copies? Fuchs are used on T...   Mar 2 2018, 03:58 PM
bryans914   Are you Fuchs real or copies? Fuchs are used on ...   Mar 3 2018, 02:38 PM
bryans914   Are you Fuchs real or copies? Fuchs are used on T...   Mar 3 2018, 01:18 PM
rgalla9146   Fuchs barrels ? Are your wheels built up from F...   Mar 2 2018, 04:08 PM
bryans914   Fuchs barrels ? Are your wheels built up from ...   Mar 3 2018, 01:34 PM
bryans914   Fuchs barrels ? Are your wheels built up from ...   Mar 3 2018, 02:33 PM
jmitro   one of these should be more than enough: http://w...   Mar 2 2018, 05:17 PM
bryans914   one of these should be more than enough: http://...   Mar 3 2018, 02:24 PM
infraredcalvin   You may want to stop hitting the gators on track.....   Mar 3 2018, 01:39 AM
bryans914   You may want to stop hitting the gators on track....   Mar 3 2018, 02:09 PM
jd74914   Do you have a better picture of that control arm? ...   Mar 3 2018, 01:21 PM
bryans914   Do you have a better picture of that control arm?...   Mar 3 2018, 01:39 PM
sixnotfour   there is several version of fuch 3 piece centers, ...   Mar 3 2018, 01:44 PM
bryans914   there is several version of fuch 3 piece centers,...   Mar 3 2018, 02:19 PM
Larmo63   There are basically two really good choices with c...   Mar 3 2018, 04:28 PM
Mueller   http://www.diamondracingwheels.com/index.p...detai...   Mar 3 2018, 05:00 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:51 PM
