> 914 race suspension front A arms, Do you know a source of 962 style lower A arms, see pic.
bryans914
post Mar 2 2018, 03:12 PM
(IMG:style_emoticons/default/WTF.gif)
Need source for 962 style lower A arm for coil over on 914-6. I attached a pic.
Need to replace 8 ea 16" Fuchs/barrels with 18" inexpensive steel or mixed material race wheels. The Fuchs are breaking with 450/500bhp. Sources?
Larmo63
post Mar 3 2018, 04:28 PM
There are basically two really good choices with clickable links above. Elephant racing makes the most
exotic (expensive) version, then there is the Rebel Racing set too. These of course require coiler set-ups,
as you know.
Good luck, and we need a LOT of pictures.
bryans914   914 race suspension front A arms   Mar 2 2018, 03:12 PM
burton73   Are you Fuchs real or copies? Fuchs are used on Tu...   Mar 2 2018, 03:41 PM
mepstein   Are you Fuchs real or copies? Fuchs are used on T...   Mar 2 2018, 03:58 PM
bryans914   Are you Fuchs real or copies? Fuchs are used on ...   Mar 3 2018, 02:38 PM
bryans914   Are you Fuchs real or copies? Fuchs are used on T...   Mar 3 2018, 01:18 PM
rgalla9146   Fuchs barrels ? Are your wheels built up from F...   Mar 2 2018, 04:08 PM
bryans914   Fuchs barrels ? Are your wheels built up from ...   Mar 3 2018, 01:34 PM
bryans914   Fuchs barrels ? Are your wheels built up from ...   Mar 3 2018, 02:33 PM
jmitro   one of these should be more than enough: http://w...   Mar 2 2018, 05:17 PM
bryans914   one of these should be more than enough: http://...   Mar 3 2018, 02:24 PM
infraredcalvin   You may want to stop hitting the gators on track.....   Mar 3 2018, 01:39 AM
bryans914   You may want to stop hitting the gators on track....   Mar 3 2018, 02:09 PM
jd74914   Do you have a better picture of that control arm? ...   Mar 3 2018, 01:21 PM
bryans914   Do you have a better picture of that control arm?...   Mar 3 2018, 01:39 PM
sixnotfour   there is several version of fuch 3 piece centers, ...   Mar 3 2018, 01:44 PM
bryans914   there is several version of fuch 3 piece centers,...   Mar 3 2018, 02:19 PM
Larmo63   There are basically two really good choices with c...   Mar 3 2018, 04:28 PM
Mueller   http://www.diamondracingwheels.com/index.p...detai...   Mar 3 2018, 05:00 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:53 PM
