Something Evil This Way Comes, I Hope |
Mblizzard |
Jan 29 2018, 07:34 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Well after spending lots of $$$ and seeing lots of work coming up, I hope to finally have my car to a respectable point. Should have a decent 2.3 with TBI and Microsquirt. Koni adjustable on all 4 corners. Front and rear anti sway bars. Rear coil overs and 180lb springs. New rotors, wheel bearings front and rear. All new bushings. Adjustable drop links on the front. DIY Autotune hotspark ignition. And lots of 914 rubber goodies.
This is going to be a lot of work! Will try to document it as it progresses. |
Mblizzard |
Mar 4 2018, 02:35 PM
Well making slow progress. Installed fittings in the breather base plates for the intake air temp sensor and,the return from the oil catch can for the head vents.
Ran a few of the AN lines. I sucked it up and purchased the Kool Tool for putting on the fittings and it takes about 15 seconds to put a fitting on a poorly cut hose and 2 seconds for a clean cut. Well worth the $30 bucks. Not a single bandaid need! |
Lo-Fi Version | Time is now: 6th June 2024 - 09:29 AM |
