| jkb944t |
Mar 22 2017, 11:07 AM
Member ![]() ![]() Group: Members Posts: 470 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I am considering an alternate plan for a left side ignition switch conversion. My plan is to alter a standard 914-4 steering column to accept a left side 911 ignition switch including the locking feature.
I would remove the right hand ignition switch and possibly fill in the area like some others have done. The other option would be to insert a push button switch instead of the key tumbler and use it to energize a windshield washer pump motor. I will need to get some dimensions shown on the photo so I know how to modify the standard 914-4 column to accept the 911 ignition switch. It would be very helpful if someone can help with these dimensions. Jeff B |
| Larmo63 |
Mar 7 2018, 06:54 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
My switch is early 911/912, straight into dash. The smaller 914 style bezel fits this switch too.
As for wiring the column switches, I will most likely forgo the plug ends and do point to point. |
jkb944t Left side ignition switch conversion-Alternate Idea Mar 22 2017, 11:07 AM
SixerJ Jeff, I should be able to get the dims for you off... Mar 22 2017, 05:04 PM
jkb944t
Jeff, I should be able to get the dims for you of... Mar 23 2017, 05:47 AM
SixerJ Hi Jeff, 1st off apologies for the delay, work and... Apr 3 2017, 02:32 PM
jkb944t I have restarted working on this project again thi... Mar 1 2018, 12:15 PM
gothspeed Wow! it looks amazing!! it seems like... Mar 1 2018, 02:20 PM
jkb944t I made some substantial progress this weekend.
I ... Mar 5 2018, 12:13 PM
Mueller Nice work!
I see more "conversions... Mar 5 2018, 12:26 PM
raynekat Curious about the wiring differences between the 9... Mar 6 2018, 12:01 AM
Curious about the wiring differences between the ... Mar 6 2018, 07:04 AM
jkb944t
Curious about the wiring differences between the ... Mar 6 2018, 12:15 PM
914forme That is ingenious work yet lots of hassle, for a k... Mar 6 2018, 07:28 AM
Larmo63 Something I was planning on taking on in the futur... Mar 6 2018, 09:40 AM
Larmo63 And.......
Mar 6 2018, 09:41 AM
jkb944t
And.......
The part that will be difficult wi... Mar 6 2018, 12:56 PM
Chris Scott Jeff,
I have already removed my ignition switch fr... Mar 6 2018, 10:01 AM
jkb944t The wiring is very simple for the switch except fo... Mar 7 2018, 06:47 AM
gothspeed Nice job doing the metal work for the ignition. Th... Mar 7 2018, 09:38 AM
Nice job doing the metal work for the ignition. T... Mar 7 2018, 09:55 AM
gothspeed
Nice job doing the metal work for the ignition. ... Mar 7 2018, 09:59 AM
jkb944t Getting back to the modificationā¦.next step is m... Mar 7 2018, 11:59 AM
gothspeed
I have two problems to solve before I can move fo... Mar 7 2018, 12:56 PM
jkb944t
I have two problems to solve before I can move f... Mar 8 2018, 06:46 AM
Rob-O Would it be easier to just make a harness for the ... Mar 8 2018, 12:56 PM
jkb944t
Would it be easier to just make a harness for the... Mar 8 2018, 04:06 PM
ClayPerrine I moved my emergency flasher on my six conversion ... Mar 8 2018, 02:19 PM
jkb944t
I moved my emergency flasher on my six conversion... Mar 8 2018, 04:10 PM
jkb944t Below is the modified steering housing next to the... Mar 8 2018, 04:16 PM
jkb944t Finished up the ignition switch wiring harness thi... Mar 9 2018, 07:02 AM
gothspeed workmanship is looking awesome! I like the cus... Mar 9 2018, 08:17 AM
jkb944t Thanks, just a few details to finish. Hopefully Iā... Mar 9 2018, 09:35 PM
914werke This is a great thread! Thank you Mar 9 2018, 09:38 PM
jkb944t I finished up the emergency flasher wiring harness... Mar 12 2018, 11:11 AM
Larmo63 Wow, that looks great.
Good info and step by step... Mar 12 2018, 11:59 AM
sixnotfour The plastic ones can be done with epoxy, and a fil... Mar 12 2018, 01:34 PM
jkb944t
The plastic ones can be done with epoxy, and a fi... Mar 13 2018, 03:45 PM
gothspeed Amazing results! Thank you for sharing these i... Mar 12 2018, 10:50 PM
jkb944t
Amazing results! Thank you for sharing these ... Mar 13 2018, 05:57 AM
gothspeed jkb944t if possible post pics when you get the fin... Mar 13 2018, 02:31 PM
jkb944t The pictures below show the final conversion with ... Mar 26 2018, 10:44 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th November 2025 - 08:41 AM |
