FS: Rebuilt pedal cluster |
DLewis |
Mar 22 2018, 06:42 PM
Member Group: Members Posts: 63 Joined: 3-December 04 From: Poway, CA (was SF Bay area) Member No.: 3,212 Region Association: None |
For sale a rebuilt pedal cluster for a 914 or maybe a 914/6 I am not sure about a 6.
This one was very nice to begin with. Sanded, scraped and wire wheeled it to start. Primed everything else and put a top coat of Rust-oleum Semi-gloss black. All new springs, bronze bushings, and rubber stops. Had to source a new clutch shaft from Porsche. These are getting harder and harder to rebuild but now it is perfect. Works very smooth and really one of the nicest one I have done (I have done about a dozen of these). One odd thing is it has a small cut in the bottom bracket near the clutch spring (see picture). Never seen this before. Probable someone hit it with a saw at some point. It won't really came into play, just haven't seen it before. You will have to use your brake rod, throttle linkage and brake switch. All washers, cotter pins and bushings included. $275 shipped in the US. Others, we can discuss. If you want to send me your old one I will give you $50 off (you pay shipping) if it isn't too bad, you decide. Thanks, Dean Attached thumbnail(s) |
bdstone914 |
Mar 22 2018, 07:55 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If you have this part is is then correct for a 6. The base pedal set is the same.
Lo-Fi Version | Time is now: 10th June 2024 - 09:00 AM |
