> Master Cylinder - rebuild or buy a replacement
dgraves
post Mar 30 2018, 06:24 PM
It feels like my brake master cylinder is going bad on my 1974 2.0. Since I've never rebuilt one or replaced one on the 914, I'm looking suggestions and parts sourcing. Any help out there?
Thank you.
iankarr
post Mar 30 2018, 08:46 PM
What makes it feel like the MC is failing? When was the last time the system was bled with new fluid? Over time, DOT 3 & 4 brake fluid pull humidity from the air, which leads to decreased braking response. If it hasn't been changed in a while, that could be the cause.
The 19mm MC is a great upgrade regardless. Here's the install video I made for the 914rubber one...hope it helps.
https://www.youtube.com/watch?v=N6ZHK5f_9bE
dgraves
post Apr 1 2018, 08:55 AM
QUOTE(cuddy_k @ Mar 30 2018, 08:46 PM) *
Thanks, Cuddy.
I just had 4 PBM Performance calipers installed. Lines were bled many times. No leaks in the lines or at the caliper. My mechanic and I are assuming the master cylinder. I had to take the car home and do this research. Sounds like my MC...doesn't it.
dgraves   Master Cylinder - rebuild or buy a replacement   Mar 30 2018, 06:24 PM
bbrock   I looked high and low for a rebuild kit and my und...   Mar 30 2018, 06:43 PM
dgraves   I looked high and low for a rebuild kit and my un...   Mar 30 2018, 06:56 PM
bbrock   I looked high and low for a rebuild kit and my u...   Mar 30 2018, 08:15 PM
Coondog   Perfect time to upgrade to a 19mm master cylinder,...   Mar 30 2018, 07:01 PM
cuddy_k   What makes it feel like the MC is failing? When wa...   Mar 30 2018, 08:46 PM
bdstone914   What makes it feel like the MC is failing? When w...   Mar 30 2018, 09:20 PM
dgraves   What makes it feel like the MC is failing? When w...   Apr 1 2018, 08:55 AM
aharder   go for the 19MM from 914Rubber :D   Mar 30 2018, 08:47 PM
drem914   go for the 19MM from 914Rubber :D Second that...   Mar 30 2018, 08:51 PM
steuspeed   I went with the 17mm Ate from Pelican Parts. ...   Mar 30 2018, 10:37 PM
porschetub   I went with the 17mm Ate from Pelican Parts. ...   Mar 31 2018, 01:06 PM
mepstein   I would do the soft lines at the same time. They d...   Mar 31 2018, 05:35 AM
The Cabinetmaker   I agree on the soft lines. They degrade from the i...   Mar 31 2018, 11:18 AM
JFG   I looked for ages for a kit for my 19mm but could ...   Mar 31 2018, 01:25 PM
The Cabinetmaker   To much liability to sell rebuild kits to people w...   Mar 31 2018, 02:18 PM
bbrock   To much liability to sell rebuild kits to people ...   Mar 31 2018, 02:52 PM
cuddy_k   If everything is new, it could be that the pads ha...   Apr 1 2018, 12:59 PM
cal44   Do you have two bleed nipples on each caliper? O...   Apr 1 2018, 01:26 PM
dgraves   Do you have two bleed nipples on each caliper? ...   Apr 1 2018, 03:56 PM
- Lo-Fi Version Time is now: 9th July 2025 - 12:00 PM
