Something Evil This Way Comes, I Hope |
Mblizzard |
Jan 29 2018, 07:34 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Well after spending lots of $$$ and seeing lots of work coming up, I hope to finally have my car to a respectable point. Should have a decent 2.3 with TBI and Microsquirt. Koni adjustable on all 4 corners. Front and rear anti sway bars. Rear coil overs and 180lb springs. New rotors, wheel bearings front and rear. All new bushings. Adjustable drop links on the front. DIY Autotune hotspark ignition. And lots of 914 rubber goodies.
This is going to be a lot of work! Will try to document it as it progresses. |
DRPHIL914 |
Apr 1 2018, 03:43 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
mike are you still with 4 lug, or did you upgrade to 5?
- looks lime four on those new rotors- if so, where did yoy get drilled rotors that fit with stock calipers? |
Mblizzard |
Apr 1 2018, 04:32 PM
mike are you still with 4 lug, or did you upgrade to 5? - looks lime four on those new rotors- if so, where did yoy get drilled rotors that fit with stock calipers? Still 4. Had them done in CA by Performance Brake. About $150 with pads and because they come with lifetime warranty doesn’t matter if the crack or warp. Got a set for wife’s Boxster as well. Seem to be good stuff. The can do the 5 lug as well. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:21 AM |
