Ben's 914 TURBO Official World Premier, 'cuz it didn't blowd up. |
airsix |
Sep 13 2004, 01:04 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Ok, so it isn't as cool as Chapman's 914-6 Turbo 3.0, but it's a turbo 914 all the same. Ladys and Gentlemen, at about 10:00 PST I got boost and there was much rejoicing. I took the car out, filled it with premium, tuned it with the laptop a little to make sure it got plenty of fuel under boost, and the mission was a sucess. Boost starts to come on at ~2,700rpm and is going full-steam by 3,500rpm.
I stand (ok, sit) here before you my brothers to declare that yes indeed, you can turbo a 914. (IMG:style_emoticons/default/clap56.gif) Details: Engine: '73 1.7, stock internals EFI ECU: Perfect Power MIC3 (Cost ~$500 to get on the car and running 3 years ago) Misc EFI stuff: Subaru 1.8T injectors, Holly throttle body off a 3.0 Chrysler, BMW 5xx fuel pump, foam motorcycle aircleaner (temporary) Turbo: IHI off 1.8L Subaru (including wastegate) Misc Turbo stuff: Bosch blow-off valve (for a Saab I think). Cheap. Plastic. Works great. Total cost to add turbo: $175 (EFI was already on the car. Use Megasquirt+turbo and you can do this for <$400 easy) I tried to modify my fuel pressure regulator with a boost-reference port like the in the dune-buggy.com article but I broke off a wire guage drill bit about 1.5" deep into the bolt. Dang. Only had about a quarter-inch to go too. So I just bolted it back on the car and set the fuel pressure at the 30psi I have the ECU turned for. I tried to crank up the injector pulse width under boost to compensate, but they hit 100% duty cycle at 5,000rpm because at that point they only have 20psi effective pressure (because there's 10lb of boost by that point). So I'm keeping it under 5k rpm until I get a rising-rate pressure regulator. The wideband O2 says mixtures are just fine below that point. I estimate I'm getting 110hp (That's not a WAG. I really did the math) which doesn't sound like much but is sure better than the 80hp I had before. I would still like to add an intercooler which could put it in the neighborhood of 130hp without getting too boost-happy. Even as it is now I would say it's 100% more fun to drive. I'm really happy about it. I'll get the pressure regulator issue squared away so I can run it up to 6k and I think it'll keep me happy for quite a while. Rick said "This thread is worthless without pictures" so here's the best I could do. If you missed the earlier thread I'll throw in one of the earlier pics too. I tried to make a video but all you hear is wind noice and the blow-off valve between shifts. |
soloracer |
Nov 12 2004, 11:04 AM
Senior Member Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 |
I've seen video clips of that mini van. Pretty impressive to watch a soccor mom van from the 80's taking down a newer style camaro. Too bad about Gus though. Doesn't seem right sometimes the way things go.
On the intercooler side I bought 2 Porsche 944 Turbo intercoolers. I'm not sure of their flow rates as compared to those in the charts Brian posted but they are a sturdy bar and plate unit and I believe they are good for 400 hp each as well. They are shipped more like a brick than a tile so their mounting positions would be different. Some RX7 guys have used them as well. I'm thinking of welding these two together and having custom end plates made. I just have to find a good place to mount them now. I'm thinking somewhere in the rear trunk and have the air "dragged" through them as opposed to front mount where it is rammed through. The exit venting would be either out between the tail lights or the trunk floor. Here is a pic of one sitting on the floor underneath my car. Don't use the tires for size comparison - they're a little bigger than stock.... (IMG:style_emoticons/default/wink.gif) Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:05 AM |
