| bbrock |
Apr 5 2018, 08:58 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I know valve adjustment screws have discussed to death, but frankly, the information is all over the mat and the more I read, the more confused I get. I'm hoping to get some clarity for my build. Here's the situation: stock "GA" 2.0L engine. The only mod on this engine is the OE camshaft got a mild regrind for carbs and I installed euro spec (flat top) pistons. This is not a performance build, just looking for reliability.
The heads are in Sonoma being rebuilt right now and, based on advice from this forum, will get a new set of SS valves. I have a box full of rocker assemblies from several engines, including both 8mm and 10mm versions. My original plan was to install the 10mm rockers with a new set of OE adjustment screws, but I have read that SS valves require either swivel foot adjusters or lash caps to protect the stem ends. True or False? Manley valves have hardened tips (IMG:style_emoticons/default/confused24.gif) If it's true that SS valves need extra protection, I like the swivel foot adjuster options, but they are damn expensive and i AM trying to stay in a budget here. Lash caps seems the less expensive option but what is the best way to deal with the extra length they add to the valve stems? Again, I'm just looking for a reliable engine that provides new stock performance. I'm not interested in upgrades that only benefit high performance engines or provide nothing but bragging rights. Thanks in advance for any advice. |
| bbrock |
Apr 5 2018, 01:03 PM
Thanks Zach,
My question is, why? I don't doubt the elephant feet are better (quieter, less side loading, better valve rotation, cures erectile dysfunction, etc.), but at a minimum of $250 for a set of authentic Porsche adjusters, those are expensive screws. I want to know that investment will translate into increased longevity of the engine. If the SS valve tips are hardened, why would OE adjuster screws punish them any more than they do stock valves? (IMG:style_emoticons/default/confused24.gif) I have plenty of rockers from 1.7s, my 2.0, and a bus. BTW, is the only difference between 2.0 and 1.7 the size of the adjustment screws? I ask because my 2 liter had 8mm screws (mid-73 MY). My 10mm set came out of a bus. |
bbrock Valve Adjusters Revisited - Now also valve lash caps! Apr 5 2018, 08:58 AM
Vacca Rabite You want the elephant foot adjusters if you are ma... Apr 5 2018, 09:49 AM
mtndawg I wonder if you can use these...
https://www.cbper... Apr 5 2018, 01:15 PM
MarkV I had Hamm rebuild my heads a few years ago when h... Apr 5 2018, 01:26 PM
bbrock
[url=https://www... Apr 5 2018, 03:10 PM
MarkV Yes.... sounds like someone shaking a coffee can f... Apr 5 2018, 03:54 PM
HAM Inc I had a set of these in my shop for a visual evalu... Apr 5 2018, 06:00 PM
914Sixer I have the 10MM set up that I am going to use on t... Apr 5 2018, 06:25 PM
bbrock
I have the 10MM set up that I am going to use on ... Apr 5 2018, 07:04 PM
Vacca Rabite
Last question... for now :) What is the first in... Apr 5 2018, 07:34 PM
MarkV I need to stay off this board... or I will end up ... Apr 5 2018, 07:25 PM
bretth I bought a 68 bus back in 2000 that had 52,000 mil... Apr 5 2018, 07:47 PM
bbrock
I need to stay off this board... or I will end up... Apr 5 2018, 07:56 PM
MarkV If you do the adjusters you have to switch to chro... Apr 5 2018, 08:12 PM
bbrock
If you do the adjusters you have to switch to chr... Apr 5 2018, 08:30 PM
MarkV It's been a while since I did it but I think y... Apr 5 2018, 08:53 PM
jjs3rd914 Subject valve lash caps??
Okay who has experience ... Apr 6 2018, 10:44 AM
bbrock
Okay who has experience... Apr 6 2018, 12:48 PM
brant I'm not a builder...
but I "believe... Apr 6 2018, 01:35 PM
914Sixer Here you go. This guy can answer all your questio... Apr 6 2018, 08:10 PM
MarkV https://www.thesamba.com/vw/classifieds/det....php... Apr 6 2018, 09:07 PM
Mark Henry I've used every method there is ...do it right... Apr 6 2018, 09:27 PM
nditiz1 Bbrock - I am in the same boat as you. I am getti... Apr 17 2018, 09:55 AM
McMark I use 911 adjusters on all my builds. And if you... Apr 17 2018, 10:53 AM
bbrock This has been a great thread. Thanks all for your... Apr 17 2018, 07:01 PM
McMark Count on cutting new pushrods. ;) But maybe you... Apr 18 2018, 11:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:11 PM |
