> Valve Adjusters Revisited - Now also valve lash caps!
bbrock
post Apr 5 2018, 08:58 AM
I know valve adjustment screws have discussed to death, but frankly, the information is all over the mat and the more I read, the more confused I get. I'm hoping to get some clarity for my build. Here's the situation: stock "GA" 2.0L engine. The only mod on this engine is the OE camshaft got a mild regrind for carbs and I installed euro spec (flat top) pistons. This is not a performance build, just looking for reliability.
The heads are in Sonoma being rebuilt right now and, based on advice from this forum, will get a new set of SS valves. I have a box full of rocker assemblies from several engines, including both 8mm and 10mm versions. My original plan was to install the 10mm rockers with a new set of OE adjustment screws, but I have read that SS valves require either swivel foot adjusters or lash caps to protect the stem ends. True or False? Manley valves have hardened tips (IMG:style_emoticons/default/confused24.gif)
If it's true that SS valves need extra protection, I like the swivel foot adjuster options, but they are damn expensive and i AM trying to stay in a budget here. Lash caps seems the less expensive option but what is the best way to deal with the extra length they add to the valve stems?
Again, I'm just looking for a reliable engine that provides new stock performance. I'm not interested in upgrades that only benefit high performance engines or provide nothing but bragging rights.
Thanks in advance for any advice.
914Sixer
post Apr 5 2018, 06:25 PM
I have the 10MM set up that I am going to use on the HAM heads. I had my work done by a guy in LA. Machined the rockers for swivel feet and machined the rocker end shafts to use a solid center spacer with shims so rocker is dead center on top of valve. I was waiting to show set up when the new heads get here.
bbrock
post Apr 5 2018, 07:04 PM
QUOTE(914Sixer @ Apr 5 2018, 06:25 PM) *
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
Alright, I'm back in the hunt. Len's confirmation that they do increase guide and valve life is the sort of justification I needed. If the TP screws pan out, it makes it a no brainer since it would be even less expensive than replacing the OE screws with genuine Porsche parts and about the same as after market. You may have answered my question already Mark, but given that I have my choice of rockers, I wonder if there is a benefit going with the 10mm set.
I haven't found anything negative about the TP screws on Samba yet, but still digging. Another worm popped out of the can I opened though. Looks like I should use solid spacers on the shafts instead of the OE spring and shim setup? I think I need to read up on setting valve geometry. I was operating under the assumption that only applied when modifications were being made.
Last question... for now (IMG:style_emoticons/default/smile.gif) What is the first indication of a crappy adjustment screw? Do the valves just start going out of adjustment fast? I've had the pleasure of driving my bus when a valve broke. Blew a hole right through the case. I need to take care of my matching numbers baby here. (IMG:style_emoticons/default/wub.gif)
bbrock   Valve Adjusters Revisited - Now also valve lash caps!   Apr 5 2018, 08:58 AM
Vacca Rabite   You want the elephant foot adjusters if you are ma...   Apr 5 2018, 09:49 AM
bbrock   Thanks Zach, My question is, why? I don't do...   Apr 5 2018, 01:03 PM
mtndawg   I wonder if you can use these... https://www.cbper...   Apr 5 2018, 01:15 PM
MarkV   I had Hamm rebuild my heads a few years ago when h...   Apr 5 2018, 01:26 PM
bbrock   I wonder if you can use these... [url=https://www...   Apr 5 2018, 03:10 PM
MarkV   Yes.... sounds like someone shaking a coffee can f...   Apr 5 2018, 03:54 PM
HAM Inc   I had a set of these in my shop for a visual evalu...   Apr 5 2018, 06:00 PM
914Sixer   I have the 10MM set up that I am going to use on t...   Apr 5 2018, 06:25 PM
bbrock   I have the 10MM set up that I am going to use on ...   Apr 5 2018, 07:04 PM
Vacca Rabite   Last question... for now :) What is the first in...   Apr 5 2018, 07:34 PM
MarkV   I need to stay off this board... or I will end up ...   Apr 5 2018, 07:25 PM
bretth   I bought a 68 bus back in 2000 that had 52,000 mil...   Apr 5 2018, 07:47 PM
bbrock   I need to stay off this board... or I will end up...   Apr 5 2018, 07:56 PM
MarkV   If you do the adjusters you have to switch to chro...   Apr 5 2018, 08:12 PM
bbrock   If you do the adjusters you have to switch to chr...   Apr 5 2018, 08:30 PM
MarkV   It's been a while since I did it but I think y...   Apr 5 2018, 08:53 PM
jjs3rd914   Subject valve lash caps?? Okay who has experience ...   Apr 6 2018, 10:44 AM
bbrock   Subject valve lash caps?? Okay who has experience...   Apr 6 2018, 12:48 PM
brant   I'm not a builder... but I "believe...   Apr 6 2018, 01:35 PM
914Sixer   Here you go. This guy can answer all your questio...   Apr 6 2018, 08:10 PM
MarkV   https://www.thesamba.com/vw/classifieds/det....php...   Apr 6 2018, 09:07 PM
Mark Henry   I've used every method there is ...do it right...   Apr 6 2018, 09:27 PM
nditiz1   Bbrock - I am in the same boat as you. I am getti...   Apr 17 2018, 09:55 AM
McMark   I use 911 adjusters on all my builds. And if you...   Apr 17 2018, 10:53 AM
bbrock   This has been a great thread. Thanks all for your...   Apr 17 2018, 07:01 PM
McMark   Count on cutting new pushrods. ;) But maybe you...   Apr 18 2018, 11:43 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:13 PM
