Push rod tube seal leaks, sealant or not?? going to do mine second time and dont want leaks! |
DRPHIL914 |
Mar 7 2018, 10:05 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I was very careful last time with this, followed the directions of the late Captn,
just used oil as lube and slipped them in place. some leak some don't, many say no sealant some have used RTV - looking for more advice so I don't have to do this again Phil |
914Toy |
Apr 6 2018, 01:24 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
I tried all of the suggestions above with varying poor results. Finally an old pro suggested try a new set of push rod tubes new tubes along with the new brown "O" rings. No more oil leaks!
98101 |
Apr 6 2018, 01:30 PM
Michael in Seattle Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
I tried all of the suggestions above with varying poor results. Finally an old pro suggested try a new set of push rod tubes new tubes along with the new brown "O" rings. No more oil leaks! We'll be changing the transmission (and adding a Chris Foley linkage) and clutch soon. I'm thinking it could be easier just to take the whole engine out and do this. Looks like the pushrod tubes cost about $12 each. Unclear if I shouldn't just order these beforehand. Mechanic doesn't want my car using up one of his bays while waiting for parts. |
98101 |
Apr 6 2018, 05:58 PM
I tried all of the suggestions above with varying poor results. Finally an old pro suggested try a new set of push rod tubes new tubes along with the new brown "O" rings. No more oil leaks! We'll be changing the transmission (and adding a Chris Foley linkage) and clutch soon. I'm thinking it could be easier just to take the whole engine out and do this. Looks like the pushrod tubes cost about $12 each. Unclear if I shouldn't just order these beforehand. Mechanic doesn't want my car using up one of his bays while waiting for parts. Update: Now I've heard 914Rubber has the pushrod tubes for $8 each. If you were me, would you replace these while doing the seals? |
Lo-Fi Version | Time is now: 9th June 2024 - 10:48 AM |
