Dellorto Fuel Problem, Dellorto Carb Issues |
mharrison |
Nov 12 2004, 12:21 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
I have a pair of 40 DRLA Dellortos on my '72 914. I had some problems with the accelerator pumps, but I removed the pump diaphragm and glew air through the hole to free up the ball bearing like valve in there. Now one is pumping, but the other is not. The accelerator pump arm is moving, it sounds like it is pumping are when off the car, but when I hook the fuel back up, I can't get it to pump. I'm going to pull it apart again and check the float, but do you guys have any pearls of wisdom on anything else that I might be able to check while I've got it off the car?
-Matt |
SLITS |
Nov 12 2004, 01:01 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
You could feasibly have a pin hole in the diaphram or the flat spring that seats the ball is not functioning correctly.
Lo-Fi Version | Time is now: 16th June 2024 - 01:29 AM |
