What would URY do?, Door handle disassembly |
ConeDodger |
Apr 21 2018, 01:58 PM
Apex killer! Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
So, I finished drilling. Looks pretty good, but not up to the work that has already been done. So I need to disassemble and send the two main parts of each handle off to Ogden Chrome for a refresh.
What have you guys done? I know Paul takes these apart all the time. I don't suppose it's possible to do without destroying the rivet that it pivots on? Attached image(s) |
URY914 |
Apr 22 2018, 05:39 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
You could have asked me directly. (IMG:style_emoticons/default/confused24.gif)
ConeDodger |
Apr 22 2018, 06:39 AM
Yes, but it’s a forum. How is the collective knowledge benefitted by my asking you directly? (IMG:style_emoticons/default/happy11.gif) Do you just use a bolt to put it back together or is the rivet still a parts counter thing? |
URY914 |
Apr 22 2018, 07:00 AM
Yes, but it’s a forum. How is the collective knowledge benefitted by my asking you directly? (IMG:style_emoticons/default/happy11.gif) Do you just use a bolt to put it back together or is the rivet still a parts counter thing? Reuse the pin. The tension on the pin will keep the pin in the hole. Reinstall the filed off end of the pin on the bottom of the handle. I've never had a pin back out. |
ConeDodger |
Apr 22 2018, 08:09 AM
Yes, but it’s a forum. How is the collective knowledge benefitted by my asking you directly? (IMG:style_emoticons/default/happy11.gif) Do you just use a bolt to put it back together or is the rivet still a parts counter thing? Reuse the pin. The tension on the pin will keep the pin in the hole. Reinstall the filed off end of the pin on the bottom of the handle. I've never had a pin back out. (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 03:19 PM |
