> Uncharted Territory, Clutch Replacement
loco914
post Apr 21 2018, 09:13 PM
Thy wheels have left the rail...
First engine/tranny drop was successful.
Pulled the clutch and found this...
The adventure begins...
loco914
post Apr 22 2018, 05:04 PM
Ok. This is hopefully as far as I will go.
Having trouble confirming the source of all the oil on top as it is literally everywhere. Possibly coming from loose vacuum connections?
Leak on the bottom is from my arch nemesis the taco plate. Pushrod tubes seem to be holding their own.
Looking for thoughts on how best to clean all the crap off and out of the fins??
Can the oil cooler be cleaned or is it a lost cause?
Thanks.
rgalla9146
post Apr 22 2018, 05:30 PM
QUOTE(loco914 @ Apr 22 2018, 07:04 PM) *
Thanks.
Some oil is over the tin, some under.
I'd do OP switch, every seal on the oil filler tower and check the seals on the
cooler.
Make sure your crankcase is vented properly.
Get the cheapest piece of 4' x 8' plywood and a gallon of mineral spirits
and get busy with any brush you can find. The filth will transfer from the engine
onto you.
Find some plugs for the cooler and wash it with mineral spirits, it will come clean.
loco914   Uncharted Territory   Apr 21 2018, 09:13 PM
GeorgeRud   I think you got your money’s worth out of those ...   Apr 21 2018, 10:18 PM
porschetub   That's messy,don't often see a disk do tha...   Apr 22 2018, 02:04 AM
Porschef   Throw in some SS fuel lines while the engine's...   Apr 22 2018, 06:23 AM
loco914   Here’s the flywheel. Plan to remove and have it ...   Apr 22 2018, 12:12 PM
porschetub   Here’s the flywheel. Plan to remove and have it...   Apr 22 2018, 06:00 PM
loco914   Just don’t understand why it would run hot.... :...   Apr 22 2018, 12:41 PM
Superhawk996   Just don’t understand why it would run hot.... ...   Apr 12 2020, 02:22 PM
98101   Going to do my clutch (pushrod tube seals, rear ma...   Apr 22 2018, 01:42 PM
loco914   Going to do my clutch (pushrod tube seals, rear m...   Apr 22 2018, 03:59 PM
loco914   Ok. This is hopefully as far as I will go. ...   Apr 22 2018, 05:04 PM
rgalla9146   Ok. This is hopefully as far as I will go. ...   Apr 22 2018, 05:30 PM
nditiz1   Not trying to hijack, but can someone tell me how ...   Apr 22 2018, 05:38 PM
Andyrew   Not trying to hijack, but can someone tell me how...   Apr 23 2018, 11:55 AM
Perry Kiehl   You are going to run much cooler with all the moto...   Apr 22 2018, 07:16 PM
loco914   Thanks for all the tips! Keep them coming. It ...   Apr 22 2018, 09:42 PM
Dr Evil   Don't forget the TOB and to see if you need to...   Apr 23 2018, 09:02 AM
loco914   A little progress last night and today. Got the mu...   May 5 2018, 06:55 PM
porschetub   A good clean on the housing you will be good,if yo...   May 5 2018, 11:56 PM
Amphicar770   Fun stuff. Did mine about a year ago. There are...   May 6 2018, 09:30 AM
Amphicar770   Regarding oil cooler. They are not expensive. I go...   May 6 2018, 09:53 AM
loco914   Regarding oil cooler. They are not expensive. I g...   May 7 2018, 12:45 PM
loco914   Slow, but making progress. Estimating the equivale...   May 12 2018, 01:11 PM
cuddy_k   Steam cleaner. Under 100 bucks at HF. https://ww...   May 12 2018, 02:08 PM
1adam12   I just finished cleaning my engine up. Took about...   May 12 2018, 03:02 PM
loco914   Very nice! Much needed motivation.   May 12 2018, 04:09 PM
Mark Henry   http://www.914world.com/bbs2/uploads/post-11542-15...   May 12 2018, 04:12 PM
loco914   Almost 2 years to the day, I finally have my 914 b...   Apr 12 2020, 02:18 PM
loco914   Before.   Apr 12 2020, 02:30 PM
loco914   Before.   Apr 12 2020, 02:32 PM
loco914   After.   Apr 12 2020, 02:33 PM
loco914   Before. For the 3rd time.   Apr 12 2020, 02:34 PM
loco914   Rebuilt pedal board.   Apr 12 2020, 02:38 PM
loco914   Ready to install   Apr 12 2020, 02:39 PM
loco914   All buttoned up.   Apr 12 2020, 02:40 PM
loco914   Off the ramps and ready to roll, :driving:   Apr 12 2020, 02:41 PM
- Lo-Fi Version Time is now: 14th September 2026 - 12:23 PM
