Advice on axle suppport with engine removed |
sixaddict |
Apr 21 2018, 02:12 AM
Senior Member Group: Members Posts: 804 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
I have seen this at shop but do not remember how it was done. Have engine /trans removed for some chassis reinforcement work and will be moving car around...
What is best way to suspend axles so they are not "flopping" around.... ( I do not want to remove ---too lazy (IMG:style_emoticons/default/dry.gif) ) TIA |
914forme |
Apr 24 2018, 08:20 PM
You could get an extra set of stubs and just pull you CVs and stubs out, install the new stubs and you have the best of both worlds.
Also let you check and see if your inner CVs need a bit of TLC. Mark them and swap side to side to run them in a different pattern. That Being Said, Chris' stuff is very nice if you need to keep one mobile for long periods of time. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:22 AM |
