| Mikey914 |
Mar 3 2018, 11:57 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Includes
Main Windshield top seal 91456303910 Lower main seal 91456331910 Roof to window seals 1 - 91453118510 - left targa top side seal 1 - 91453118610 - right targa top side seal Vertical targa seals 1 - 91453114310 - left rollbar side seal 1 - 91453114410 - right rollbar side seal #9 &28. 20 &36 in sets. With 14 as an option Will include a copy of the factory maintenance manual to allow you to locate the adjustments for the door windows. I am working on installation instructions and techniques you can use to install these that will be available in about 9 days and can be emailed to you. There is a re occurring theme that these seals are difficult to install correctly, and if not installed correctly will allow for more water to enter your cabin. This is my attempt to put together a kit in a format that will educate the installers as to what you need to do and not do at least from my experience. The 914 is prone to leaking, but lets minimize that to the extent possible. Will have option to purchase the OEM profile rear seal with the fuzzey for $42 (1/2 off) only with the kit. https://900designs.zoeysite.com/914/914-cha...rts/811-00-roof Attached thumbnail(s) |
| Mikey914 |
Apr 25 2018, 12:21 AM
Email sent. The trick is to install the upper corners 1st. The vertical sides do not slide through the track. The back side engages in the inside of the track. You push it forward onto the tab on the aluminum, and install the screw in the corner hole that holds it. Work your way down the sides starting the back 1st. It is a tight fit as it needs to stay in. Use a flat screwdriver to push the front side in. You will notice that the factory took a tool and punched the chrome down at the bottom. You will need to use the same large flat screwdriver to carefully bend the punched part out of the track. Note this is new rubber and will be slightly larger than the old as it shrinks over time. It may be necessary to make some fine adjustments to the tilt of the bar as it's slightly larger. I didn't have to on mine, but I adjusted mine when I fitted the 1st Gen 5 years ago.
Hope this helps we are working on more extensive install instructions. Thanks, mark |
Mikey914 GB limited quantity 20 sets only Cabin seal set $214 Mar 3 2018, 11:57 AM
Mikey914 More Mar 3 2018, 11:59 AM
mb911
More
In for set.. Mar 3 2018, 12:54 PM
cn2800 One set for me, please! Mar 3 2018, 04:57 PM
cn2800
Oops. Plus #14 as w... Mar 3 2018, 11:19 PM
rhodyguy Wow. Mar 3 2018, 03:09 PM
markhoward I'm in for a set too.. +14 Mar 3 2018, 04:54 PM
Chris914n6 I was going to give you crap about slacking on the... Mar 3 2018, 05:07 PM
Mercurial Count me in...+14 Mar 3 2018, 05:23 PM
jet1 Please add me to the list +14 as well Mar 3 2018, 06:12 PM
Flightpath I will take a set with the option on #14 Mar 3 2018, 06:16 PM
carking1996 I'm in! Mar 3 2018, 06:17 PM
plays with cars I'm in for a set. +14 for me too.
Point of cl... Mar 3 2018, 10:28 PM
Mikey914
Point of c... Mar 4 2018, 04:12 AM
Daiberl In for one set, + #14 Mar 3 2018, 11:32 PM
JamesM Perfect timing. Count me in! Mar 3 2018, 11:59 PM
jcd914 The timing is not great but I need these.
I'm ... Mar 4 2018, 01:20 AM
gus'914 I am in for a set plus 14, Thanks. Mar 4 2018, 01:55 AM
98101 If there is a single raindrop or gust of wind, it ... Mar 4 2018, 02:20 AM
Gary I'll take a set, +14. thnx. Mar 4 2018, 05:50 AM
billh1963 I'll take a set! Mar 4 2018, 07:05 AM
914four One kit please. Mar 4 2018, 07:26 AM
Mikey914 PMs sent to all Mar 4 2018, 01:28 PM
Shadowfax One set please plus No. 14. Thanks! Mar 4 2018, 01:42 PM
mb911 Paid already thanks. Mar 4 2018, 01:51 PM
scallyk9 Add me please! I'll call in an order to in... Mar 4 2018, 02:44 PM
warpig put me down for one, and the throttle cable too.
... Mar 4 2018, 06:28 PM
Mikey914 PMs sent to all one left.
If you miss it and wa... Mar 5 2018, 12:20 AM
maf914 I'll take one set of cabin seals. I will also... Mar 5 2018, 07:36 AM
Mikey914 The cable will not be ready to ship out with thes... Mar 5 2018, 10:42 AM
Shadowfax Payment sent this morning. Thanks, Mark! Mar 5 2018, 10:51 AM
mmichalik PM sent Mar 5 2018, 10:58 AM
Dougster Put me in line for a set if someone drops out plea... Mar 5 2018, 11:11 AM
cwpeden Put me in line too! With #14 Mar 5 2018, 11:41 AM
Shadowfax Got the seals today. Installed the rear Targa seal... Mar 8 2018, 11:00 AM
Mikey914 Use a new break away blade knife knife and soapy ... Mar 8 2018, 11:43 AM
Shadowfax
Use a new break away blade knife knife and soapy... Mar 8 2018, 11:51 AM
98101
I am working on installation instructions and tec... Apr 24 2018, 04:14 PM
98101
Email sent. The trick is to install the upper cor... Apr 25 2018, 02:21 AM
Mikey914 Heres some pics from my install.
The rubber will ... Apr 25 2018, 11:46 AM
Mikey914 Stary the inside edge Apr 25 2018, 11:47 AM
Mikey914 Push in the edhe all the way down Apr 25 2018, 11:49 AM
98101 Cutting the lower part to mate with the closing do... Apr 25 2018, 09:03 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:18 PM |
