John90290 |
Member ![]() ![]() Group: Members Posts: 93 Joined: 4-March 18 From: Ventura, CA Member No.: 21,937 Region Association: None ![]() |
I spent all this time getting the floor pan to bare metal, fixing rust area, removing seam sealer and POr15'ing the entire deck now it's time to add carpet and sound proofing and I feel I'm going to cover up all my hard work?
Should I use the dynamat type stuff and go with the original tar stuff? If I add sound deading material behind the seat will the back pad fit? Did everyone else just glue their carpet down? Getting the old stuff off was a bigger pain than cutting welding the rust patches. Looking to see what you folks have done. Thank! |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,900 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
light glue only on the rocker and left and right wheel well pieces
Use the original six piece floor pan tar kit. Self sticks and beaten into place with a bit of heat and a rubber hammer, then paint factory color I spent all this time getting the floor pan to bare metal, fixing rust area, removing seam sealer and POr15'ing the entire deck now it's time to add carpet and sound proofing and I feel I'm going to cover up all my hard work? Should I use the dynamat type stuff and go with the original tar stuff? If I add sound deading material behind the seat will the back pad fit? Did everyone else just glue their carpet down? Getting the old stuff off was a bigger pain than cutting welding the rust patches. Looking to see what you folks have done. Thank! |
Lo-Fi Version | Time is now: 16th June 2024 - 03:19 PM |
