FS 5 lug converted Rear Hubs with studs $265 Shipped, 3 pair as of 3/12/2019, with or with out cores |
bdstone914 |
Apr 28 2018, 09:29 PM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Edit : Three more pair available as of 3/12/2019
Please read Eric's post on 5 lug conversion options. Make sure these are right for you. http://www.914world.com/bbs2/index.php?sho...p;hl=conversion I am selling pairs of the late (71-76) rear hubs that were redrilled to 5 x 130mm lug pattern. They do not have the extra bosses used on the 1970-1971 hubs They were stripped and black oxide coated. A professional machine shop machined them. I hand installed new 10.9 grade 14m x 45m studs. The 45mm studs are for use with steel or alloy wheels. Second picture is of hubs with out studs. Longer lenght studs for use with spacers available by request. These hubs only work with 914 stub axles and CV's. Not recommended for high (300+) HP applications. $265 no cores required shipped in the U.S. $215 With a good core of hubs returned. $75 Core deposit required. $175 with no studs. I do not accept hubs that have damage to the surface where the stub axle seats. Commonly caused using a BFH and a big socket. Thanks for looking. Attached thumbnail(s) |
Rob-O |
May 1 2018, 08:04 AM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
It’s not the hubs that can’t handle high horsepower, it’s the CV’s. This setup uses the stock 914-4 CV’s, which most believe to be good to 150-160 horsepower. Personally I think they handle a little more than that but I think that depends on your driving style.
Lo-Fi Version | Time is now: 9th June 2024 - 07:18 AM |
