> Additional oil cooler
cal914
post May 8 2018, 07:01 AM
I have a 6 engine that has been uprated to 2.2 with E cams,the temp gauge keeps edging the red part of the gauge ,I e been told by the guy who rebuilt the engine that I probably need another oil cooler,can you only have these fitted in the front boot space or are there other places in the engine bay that they can be fitted
Hope this makes sense
Thanks Brian
IronHillRestorations
post May 9 2018, 07:47 AM
I. I. R. C.
Jim, I did the first one on a 3.0 and it worked fine, I never saw over 220 on a hot day in TN.
For this project I have the rear quarter panel off, so I'm going to try and see what's the largest one that will fit.
cal914   Additional oil cooler   May 8 2018, 07:01 AM
mepstein   A couple guys have sucessfull fitted one at the tr...   May 8 2018, 07:14 AM
JmuRiz   I plan on fitting one in the transmission area...w...   May 8 2018, 07:22 AM
rgalla9146   I have a 6 engine that has been uprated to 2.2 wi...   May 8 2018, 07:32 AM
SirAndy   Under what conditions are you seeing such temp...   May 8 2018, 01:04 PM
Boomingbeetle   Summit racing and Amazon both carry this B&M k...   May 8 2018, 08:20 AM
gereed75   Lots of experience here on the board and I have wo...   May 8 2018, 08:52 AM
GeorgeRud   I think any additional cooler capacity should help...   May 8 2018, 09:02 AM
dr914@autoatlanta.com   Brian, a 2.2 should not need a remote oil cooler. ...   May 8 2018, 09:08 AM
Mikey914   I have a 1.7 Reno car that has an external cooler....   May 8 2018, 09:29 AM
cal914   This is where the temp gauge was yesterday with ou...   May 8 2018, 09:52 AM
914forme   Another item to consider is oil temp sender and ga...   May 8 2018, 09:57 AM
rgalla9146   Another item to consider is oil temp sender and g...   May 8 2018, 10:13 AM
cal914   Another item to consider is oil temp sender and g...   May 8 2018, 01:19 PM
mskala   Part number is close, should be equivalent, but th...   May 8 2018, 01:58 PM
mskala   Others already said may be a mis-match guage-to-se...   May 8 2018, 11:24 AM
porschetub   You should be running a 150C sender (300F) I would...   May 8 2018, 03:32 PM
gothspeed   You should be running a 150C sender (300F) I woul...   May 8 2018, 07:00 PM
Larmo63   My 2.4 S spec /6 HAS a front oil cooler; the needl...   May 8 2018, 03:59 PM
mb911   I will run it on my 2.4 s spec.. Thats why I had t...   May 8 2018, 05:55 PM
GeorgeRud   Those surely look beautiful! Another thought ...   May 8 2018, 06:00 PM
worn   Those surely look beautiful! Another thought...   May 8 2018, 06:57 PM
jim_hoyland   Those surely look beautiful! Another thought...   May 11 2018, 06:22 PM
mskala   If this is a conversion, did you remove the rain t...   May 8 2018, 08:15 PM
Perry Kiehl   I like to put the aux oil cooler in the right rear...   May 8 2018, 08:57 PM
JmuRiz   I like to put the aux oil cooler in the right rea...   May 9 2018, 07:14 AM
Perry Kiehl   Jim, I did the first one on a 3.0 and it worked fi...   May 9 2018, 07:47 AM
cal914   Had the timing set 29 degrees from 35 but that sti...   May 11 2018, 01:28 PM
porschetub   The engine tin seals tend to shrink with age and g...   May 11 2018, 04:59 PM
porschetub   Lots of advice on the here for the OP's issues...   May 11 2018, 11:34 PM
cal914   Lots of advice on the here for the OP's issue...   May 12 2018, 07:54 AM
porschetub   Lots of advice on the here for the OP's issu...   May 14 2018, 08:09 PM
767driver   I have a 6 engine that has been uprated to 2.2 wi...   May 14 2018, 12:54 PM
- Lo-Fi Version Time is now: 1st July 2025 - 01:57 PM
