Steering Hub Question, Momo hub - Dino wheel |
MarkV |
May 16 2003, 09:49 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I have a momo mount & just bout a Dino wheel. The Dino wheel has a slightly larger bolt patern that the Momo hub. Do they still make a Dino hub for a 73 914?
Also looks like the Dino wheel may work better w/ 5mm mach. screws vs. the 4mm the Momo takes. Has anybody re-drilled a Momo hub to fit a Dino wheel? When I mount the hub in the car there is a 1" gap between the Momo hug & the horn mechanism. I assume this gap is for the horn wiper contact. Am I missing a cover or do I have the wrong hub. The hub bolts on w/ no problem. I bouht the hub & wheel from different sellers on e-bay. (IMG:style_emoticons/default/confused24.gif) Attached image(s) |
MarkV |
May 17 2003, 09:50 AM
QUOTE(acox914 @ May 16 2003, 07:56 PM) here is a solution: send me a $20.... ill send you a personal wheel adapter and you can redrilll it (IMG:style_emoticons/default/biggrin.gif) sound like a plan? (IMG:style_emoticons/default/laugh.gif) Aaron, What is the bolt patern of your hub? I need 6 on 74mm center w/ 5mm screws. Thanks |
Lo-Fi Version | Time is now: 12th June 2024 - 12:10 AM |
