16x7 wheels, 35mm offset, fit narrow body? |
Freezin 914 |
May 17 2018, 07:49 PM
Senior Member Group: Members Posts: 871 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
I have had a set of 16x7 VTO wheels with a 35mm offset, I am thinking they wouldn’t work on my narrow body car? Is this correct? I believe I would need a 23.3 offset? I will try to look through older threads.. (IMG:style_emoticons/default/type.gif)
Attached thumbnail(s) |
Mueller |
May 17 2018, 08:04 PM
Those will fit better on the rear than a 23mm offset since they will be inboard 10mm more, still might have tire clearance issue if running 205/50's on a bone stock rear fender.
I test fit my 23mm 7" wide rims on my car and the rim pokes out past the fender a good 1/2". |
Lo-Fi Version | Time is now: 1st June 2024 - 06:16 AM |
