> No Start, 1972 914 will not start
Mike1981
post May 13 2018, 08:13 AM
Hello teeners
Looking for some advice please
I have a 72 V8 conversion (I Know not a real 14)
Really fun to drive
I just tried to start it and I do get power to dash and radio but the fule pump cuts out and no crank when I turn the key to the full starting position.
The 2 things I have notice
1 Battery was low (Now Charging)
2 No cranking no clicking nothing.
3 Fuel pump cuts out
4 flashers tied to the e-brake keep flashing
could it be the e-brake sensor?
Clutch sensor/switch?
Starter?
ignition switch?
Checked all relays and fuses I can find
All seem good.
Thanks
Mike
Mike1981
post May 20 2018, 10:58 AM
Hello Everyone
I have been cleaning connectors and checking the realy board.
I am getting 12 volts into pin 1 from the ignition switch>
Pin 1 and outgoing Pin 6 ohm out with no resistance.
However no voltage out of pin 6
Checked all 3 relays (all Working)
Scrubbed every connector I could find
Any ideas?
http://www.914world.com/bbs2/index.php?act...t&id=424733
Mike1981   No Start   May 13 2018, 08:13 AM
Perry Kiehl   If you've got a strong battery and feel the st...   May 13 2018, 06:10 PM
Vacca Rabite   The starter draws a TON of power. A dead battery ...   May 13 2018, 08:00 PM
r_towle   There is no clutch sensor There is no ebrake senso...   May 13 2018, 08:25 PM
Mike1981   Thanks Everyone for your advice. I measured 12.34...   May 14 2018, 03:04 PM
Mike1981   Hello Charged Battery overnight. It was reading 1...   May 15 2018, 02:54 PM
Mark Henry   First thing you always do, clean all the grounds, ...   May 15 2018, 05:26 PM
Mike1981   Good Advice I will clean battery terminal as well...   May 15 2018, 05:55 PM
xperu   Good Advice I will clean battery terminal as wel...   May 16 2018, 03:51 PM
rick 918-S   I am not a believer in the hot start gizmo. Porsch...   May 16 2018, 01:12 PM
jcd914   A stock 72 had a starter interlock relay under the...   May 16 2018, 03:48 PM
Mike1981   Hello Well I bought a new battery> No crank n...   May 19 2018, 07:50 AM
worn   I am sorry to tell you now that the seats slide of...   May 20 2018, 02:52 PM
Mike1981   I am sorry to tell you now that the seats slide o...   May 20 2018, 04:45 PM
Mark Henry   I am sorry to tell you now that the seats slide ...   May 20 2018, 08:29 PM
jcd914   In these pictures there is no seat belt interlock ...   May 20 2018, 11:17 PM
rick 918-S   Check the relay board connections.   May 19 2018, 07:02 PM
Mike1981   Hello Everyone I have been cleaning connectors an...   May 20 2018, 10:58 AM
jcd914   The relay/circuit board in the engine compartment ...   May 20 2018, 12:05 PM
Mike1981   The relay/circuit board in the engine compartment...   May 20 2018, 04:44 PM
Mike1981   The relay/circuit board in the engine compartment...   May 20 2018, 05:25 PM
MarkV   Try smacking the starter with a hammer. The soleno...   May 20 2018, 01:07 PM
Mark Henry   Try smacking the starter with a hammer. The solen...   May 20 2018, 02:40 PM
Mike1981   OK Had an Idea. I disconnected the 14 pin harness ...   May 20 2018, 06:11 PM
jcd914   OK Had an Idea. I disconnected the 14 pin harness...   May 20 2018, 11:28 PM
Mike1981   [quote name='Mike1981' post='2611306' date='May 2...   May 22 2018, 06:58 PM
jcd914   [quote name='Mike1981' post='2611306' date='May ...   May 22 2018, 11:06 PM
Mike1981   Anyone with any ides thanks   May 22 2018, 06:58 PM
Mark Henry   The connector main harness plug in to relay board,...   May 22 2018, 08:51 PM
Mark Henry   I didn't see you already tried what I suggeste...   May 23 2018, 05:09 AM
- Lo-Fi Version Time is now: 9th July 2025 - 12:56 PM
