Mike1981 |
Member ![]() ![]() Group: Members Posts: 245 Joined: 21-July 14 From: Phoenix Member No.: 17,663 Region Association: Southern California ![]() |
Hello teeners
Looking for some advice please I have a 72 V8 conversion (I Know not a real 14) Really fun to drive I just tried to start it and I do get power to dash and radio but the fule pump cuts out and no crank when I turn the key to the full starting position. The 2 things I have notice 1 Battery was low (Now Charging) 2 No cranking no clicking nothing. 3 Fuel pump cuts out 4 flashers tied to the e-brake keep flashing could it be the e-brake sensor? Clutch sensor/switch? Starter? ignition switch? Checked all relays and fuses I can find All seem good. Thanks Mike |
Mike1981 |
OK Had an Idea.
I disconnected the 14 pin harness jambed a wire into pin 1 crimped on a spade connector and stuck it onto the S terminal on the starter. When I turned the key the starter cranked! However I noticed the fuel pump was not humming and I believe there is one relay that controls the fuelpump on this board. Is this the case? |
Lo-Fi Version | Time is now: 9th July 2025 - 12:08 PM |
