> No Start, 1972 914 will not start
Mike1981
post May 13 2018, 08:13 AM
Hello teeners
Looking for some advice please
I have a 72 V8 conversion (I Know not a real 14)
Really fun to drive
I just tried to start it and I do get power to dash and radio but the fule pump cuts out and no crank when I turn the key to the full starting position.
The 2 things I have notice
1 Battery was low (Now Charging)
2 No cranking no clicking nothing.
3 Fuel pump cuts out
4 flashers tied to the e-brake keep flashing
could it be the e-brake sensor?
Clutch sensor/switch?
Starter?
ignition switch?
Checked all relays and fuses I can find
All seem good.
Thanks
Mike
Mike1981
post May 19 2018, 07:50 AM
Hello
Well I bought a new battery>
No crank no start
Replacced the ignition switch
No crank no start
Cleaned battery terminals no luck
Next I will begin cleaning all electrical connections with wire brushes.
I removed seat to check realy and found this...should it cut the connecton off and jump the 2 wires together?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-17663-1526737807.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-17663-1526737808.2.jpg)
worn
post May 20 2018, 02:52 PM
I am sorry to tell you now that the seats slide off the rails: you don’t have to unbolt them. Did you disconnect the seat wire or did you find it that way?
Mike1981
post May 20 2018, 04:45 PM
QUOTE(worn @ May 20 2018, 04:52 PM) *
Thanks
Yes they do slide forward but I was looking for a relay under the seat and needed the room.
I found it disconnected I will cut it off and jump the leads together.
Thanks
Mark Henry
post May 20 2018, 08:29 PM
that's what I do!
QUOTE(Mike1981 @ May 20 2018, 06:45 PM) *
Thanks
Thanks
There's a little spring stop on the one seat rail, press it and the seat slides forward right off the rails. Then you can you pull the seat right out of the car in seconds.
Hard to feel, first few times you have to get a flashlight and look down the front of the rail to see how it works.
Mike1981   No Start   May 13 2018, 08:13 AM
Perry Kiehl   If you've got a strong battery and feel the st...   May 13 2018, 06:10 PM
Vacca Rabite   The starter draws a TON of power. A dead battery ...   May 13 2018, 08:00 PM
r_towle   There is no clutch sensor There is no ebrake senso...   May 13 2018, 08:25 PM
Mike1981   Thanks Everyone for your advice. I measured 12.34...   May 14 2018, 03:04 PM
Mike1981   Hello Charged Battery overnight. It was reading 1...   May 15 2018, 02:54 PM
Mark Henry   First thing you always do, clean all the grounds, ...   May 15 2018, 05:26 PM
Mike1981   Good Advice I will clean battery terminal as well...   May 15 2018, 05:55 PM
xperu   Good Advice I will clean battery terminal as wel...   May 16 2018, 03:51 PM
rick 918-S   I am not a believer in the hot start gizmo. Porsch...   May 16 2018, 01:12 PM
jcd914   A stock 72 had a starter interlock relay under the...   May 16 2018, 03:48 PM
Mike1981   Hello Well I bought a new battery> No crank n...   May 19 2018, 07:50 AM
worn   I am sorry to tell you now that the seats slide of...   May 20 2018, 02:52 PM
Mike1981   I am sorry to tell you now that the seats slide o...   May 20 2018, 04:45 PM
Mark Henry   I am sorry to tell you now that the seats slide ...   May 20 2018, 08:29 PM
jcd914   In these pictures there is no seat belt interlock ...   May 20 2018, 11:17 PM
rick 918-S   Check the relay board connections.   May 19 2018, 07:02 PM
Mike1981   Hello Everyone I have been cleaning connectors an...   May 20 2018, 10:58 AM
jcd914   The relay/circuit board in the engine compartment ...   May 20 2018, 12:05 PM
Mike1981   The relay/circuit board in the engine compartment...   May 20 2018, 04:44 PM
Mike1981   The relay/circuit board in the engine compartment...   May 20 2018, 05:25 PM
MarkV   Try smacking the starter with a hammer. The soleno...   May 20 2018, 01:07 PM
Mark Henry   Try smacking the starter with a hammer. The solen...   May 20 2018, 02:40 PM
Mike1981   OK Had an Idea. I disconnected the 14 pin harness ...   May 20 2018, 06:11 PM
jcd914   OK Had an Idea. I disconnected the 14 pin harness...   May 20 2018, 11:28 PM
Mike1981   [quote name='Mike1981' post='2611306' date='May 2...   May 22 2018, 06:58 PM
jcd914   [quote name='Mike1981' post='2611306' date='May ...   May 22 2018, 11:06 PM
Mike1981   Anyone with any ides thanks   May 22 2018, 06:58 PM
Mark Henry   The connector main harness plug in to relay board,...   May 22 2018, 08:51 PM
Mark Henry   I didn't see you already tried what I suggeste...   May 23 2018, 05:09 AM
- Lo-Fi Version Time is now: 9th July 2025 - 12:05 PM
