> -AN Fuel tank fittings
GrayMatter
post May 22 2018, 11:30 PM
I did a quick search and came up empty. Has anyone tried these? I’m wondering if they will fit our fuel tanks.
http://www.dansperformanceparts.com/sand/s...ing-to-6an.html
GrayMatter
post May 23 2018, 08:10 AM
I had thought about the screen. Any reason why I couldn’t or shouldn’t just cut off the fuel line side and install it behind the new fitting?
McMark - you mention don’t use a washer? Not sure I understand why not. The original fittings use them from what I remember. Either way, loctite is a good call and I’ll definitely be doing that.
GrayMatter   -AN Fuel tank fittings   May 22 2018, 11:30 PM
Mark Henry   I'd have to check but I think the VW bug fitti...   May 23 2018, 05:01 AM
McMark   I did a little looking around. The tank fitting i...   May 23 2018, 06:12 AM
Mark Henry   The one issue I have, even if it fits, is the stoc...   May 23 2018, 06:24 AM
bdstone914   You can tap the inside of the fuel tank fitting to...   May 23 2018, 07:33 AM
GrayMatter   You can tap the inside of the fuel tank fitting t...   May 23 2018, 08:33 AM
Phoenix-MN   You can tap the inside of the fuel tank fitting t...   May 23 2018, 01:34 PM
theer   My "Grey Matter" project will have -AN f...   May 23 2018, 07:47 AM
GrayMatter   My "Grey Matter" project will have -AN ...   May 23 2018, 08:12 AM
cary   I have a pair of these on my car ............. htt...   May 23 2018, 08:01 AM
GrayMatter   I have a pair of these on my car ............. ht...   May 23 2018, 08:15 AM
GrayMatter   I had thought about the screen. Any reason why I c...   May 23 2018, 08:10 AM
effutuo101   I had steel AN bungs welded to the fuel tank. I am...   May 23 2018, 08:49 AM
McMark   The one issue I have, even if it fits, is the stoc...   May 23 2018, 10:19 AM
jd74914   McMark - you mention don’t use a washer? Not su...   May 23 2018, 01:46 PM
McMark   I might not be understanding what you're refer...   May 24 2018, 04:05 PM
jim912928   here is a link on how I plumbed my six conversion....   May 24 2018, 10:39 AM
Mike Bellis   I have the CB version on mine and they work great.   May 24 2018, 02:15 PM
Mike Bellis   I use an annealed copper washer with the CB fittin...   May 24 2018, 04:25 PM
- Lo-Fi Version Time is now: 19th July 2025 - 07:29 PM
