Where do you get duplicate keys made?, Double sided key giving local key makers trouble... |
Bazza |
May 23 2018, 10:14 AM
Member Group: Members Posts: 114 Joined: 26-February 05 From: New Smyrna Beach, FL Member No.: 3,661 |
Hello all.....
I only have 1 key for my teener. It's a Ilco brand duplicate that came with the car - no key code on it. I bought a couple blanks and took them to my local hardware store and the guy tried to make a duplicate but the key kept popping out when he tried to do the second side. Apparently there's not much surface area left for the gripper to hold onto. I went to a more specialized locksmith this morning and after looking at it he said he could try but couldn't guarantee success. I elected not to destroy another blank so just left. Any recommendations would be appreciated. TIA! |
ChrisFoley |
May 23 2018, 03:19 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Find a locksmith with a digital key cutter and see if they can use program New ITL #354 on key blank P05.
The cut pattern has 10 digits. Starting with the first position closest to the handle of the key the digits are numbered 1 thru 4, with one being the tallest and four being cut down practically against the fat center part of the key. If you took apart a key lock cylinder each wafer is stamped with the correct number. When I can't "see" the height of each position by eye I measure with a caliper. As I said, there are 4 heights, although some keys may not use all 4. Each height is a uniform distance from the next. This is so much better than trying to copy a worn key. |
Lo-Fi Version | Time is now: 4th June 2024 - 04:17 AM |
