| thelogo |
May 28 2018, 05:58 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
https://losangeles.craigslist.org/sfv/cto/d...6585543512.html
How fast are these and from someone who has never driven a 944 Whats it drive like .... Should i open my wallet or run like hell |
| thelogo |
May 29 2018, 10:33 PM
| Coondog |
May 30 2018, 07:43 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California
This is why your engine rebuild would cost more then the purchase of the car. Intermediate Shaft Bearing Failures: The intermediate shaft bearing is probably the most troublesome of all of the M96/M97 engine problems. The intermediate shaft bearing (IMS bearing) supports the intermediate shaft on the flywheel end of the motor. Porsche designed these motors using a sealed ball bearing that is pressed into the intermediate shaft. These types of bearings are typically used in devices like copy machines and other machinery used in dry conditions. In theory, the area where Porsche designed the bearing to sit is supposed to be dry. However, after years of use within the engine, it would appear that oil and contaminants from the engine seep past the bearing seal, wash out the original lubricant, and become trapped inside. The result is that the bearing now operates in a less-than-ideal environment and begins to wear prematurely. When the bearing wears out, the timing chains on the engine may disengage, and the engine will quickly self-destruct. When the bearing does fail, foreign object debris from the bearing circulates throughout the engine, causing further damage to other areas in the engine. |
thelogo 944 /8 conversion May 28 2018, 05:58 PM
thelogo
https://losangeles.craigslist.org/sfv/cto/d...658... May 28 2018, 06:01 PM
JmuRiz Run from that one...the lack of taste of the body ... May 28 2018, 06:07 PM
mb911 Thats an 86 and later dash in it.. It is wicked fa... May 28 2018, 06:17 PM
ConeDodger
Thats an 86 and later dash in it.. It is wicked f... May 29 2018, 10:36 AM
Elliot Cannon Ask him to throw in the mo'cycle and its a dea... May 28 2018, 06:26 PM
FL 000 You have to consider getting a smog also if you pl... May 28 2018, 06:37 PM
ConeDodger
You have to consider getting a smog also if you p... May 29 2018, 10:43 AM
Beebo Kanelle If you're in the hunt for one of these I think... May 28 2018, 07:35 PM
Andyrew
If you're in the hunt for one of these I thin... May 28 2018, 07:56 PM
KELTY360 Do some research on P.T Barnum. May 28 2018, 07:42 PM
Andyrew If it was a stock looking 944 turbo I would say ju... May 28 2018, 07:58 PM
theer 944 with a V8 is a hoot to drive! The LS moto... May 28 2018, 08:01 PM
Mike Bellis If it was in good shape, I would buy it and drive ... May 28 2018, 08:06 PM
BuddyV If you have that kind of $, look into buying ... May 28 2018, 09:44 PM
Andyrew I would 100% find as nice of a turbo as you can fo... May 29 2018, 08:41 AM
andys I wonder which 5.3 motor? If it's the 5.3 truc... May 29 2018, 08:57 AM
mb911
I wonder which 5.3 motor? If it's the 5.3 tru... May 29 2018, 10:30 AM
bretth Not one single pic of the motor? Seems like it wou... May 29 2018, 10:01 AM
Ed_Turbo That guy knows someone to have it pass smog. Looks... May 29 2018, 10:56 AM
Joemo5 Iv got a buddy with a 5.3 LS iron block with manua... May 29 2018, 04:39 PM
thelogo
[quote name='thelogo' post='2613955' date='May 29... May 30 2018, 07:13 PM
mepstein We have a former mechanic who is quite familiar wi... May 30 2018, 07:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:39 AM |
