Oh no! Lost oil pressure ... |
SirAndy |
Feb 15 2018, 08:38 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Got stuck in traffic on my way home from work today and didn't notice the oil light until the engine started making horrible noise.
Did the only thing i could think of which was to pull onto the side strip and get on the gas hoping to get oil pressure back. That actually worked! Pressure went back up to ~80 under load and ~30 at idle for the rest of the drive home but i'm afraid i might have done some permanent damage. By the time i noticed the engine noise and the pressure being at zero i was probably already running completely dry. (IMG:style_emoticons/default/headbang.gif) Now the real question is, how the heck did that happen? I checked the oil after i got home and it's still all in there. All 16 quarts of it. Could there be a blockage somewhere? Stuck piston? Clogged filter? (IMG:style_emoticons/default/sad.gif) |
IronHillRestorations |
Jun 6 2018, 09:01 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
FWIW the "old school engine flush" is 1 part kerosene or diesel to 3 parts new oil, run until it gets warm to the touch and drain. Refill with new oil, change oil in 500 miles or 8 hours. This is what a Navy mechanic told me anyway.
porschetub |
Jun 6 2018, 10:29 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
FWIW the "old school engine flush" is 1 part kerosene or diesel to 3 parts new oil, run until it gets warm to the touch and drain. Refill with new oil, change oil in 500 miles or 8 hours. This is what a Navy mechanic told me anyway. Actually you are correct,diesel is kinda ok ,reminds me when I ran a smaller stern trawler my first job as chief engineer had 2 aux engines to run domestic power and winches,we swapped load every 200 hrs but they had a habit of puking injectors before service time (2K hrs) and the oil dipstick would float up and down in the tube,used to be a mad rush to change duty (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) . We used to do overhaul them every 45K hours ,the bottom end bearing were always within service hours but replaced anyway. Anyway rant over . |
Lo-Fi Version | Time is now: 10th June 2024 - 10:08 PM |
