| jim_hoyland |
Jun 13 2018, 10:38 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,157 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I’m helping SB914 get his passenger door handle to work. The interior pull works fine; the exterior pull will not work unless I push in on the door first.
Took the handle out; it’s ok There’s not a lot of adjustment for the mechanism and i’m Trying to not remove it. Anyone else had this problem ? Attached image(s)
| bbrock |
Jun 13 2018, 01:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
There is good info in the factory manual on adjusting the striker and it wasn't intuitive to me so might be worth a look. Here are some screen grabs. Maybe they will help? (IMG:style_emoticons/default/confused24.gif)
jim_hoyland Door handle opener Jun 13 2018, 10:38 AM
Elliot Cannon I have always considered the 914 door handles to b... Jun 13 2018, 10:48 AM
914_teener Jim,
The handle looks to be very dirty. It needs... Jun 13 2018, 10:51 AM
rdauenhauer its been rebuilt. Notice that one side is a philip... Jun 13 2018, 10:55 AM
jdamiano Your door looks like it needs to be adjusted. Soun... Jun 13 2018, 10:56 AM
SirAndy Your door looks like it needs to be adjusted. Soun... Jun 13 2018, 11:26 AM
Tom_T
Your door looks like it needs to be adjusted. Sou... Jun 13 2018, 12:15 PM
bbrock
Your door looks like it needs to be adjusted. Sou... Jun 13 2018, 01:30 PM
jim_hoyland Thanks for those tips: I’ll clean the handle any... Jun 13 2018, 10:59 AM
BENBRO02
Thanks for those tips: I’ll clean the handle an... Jun 13 2018, 11:15 AM
Travis Neff The door gap sure looks tight. Also, the door cou... Jun 13 2018, 11:31 AM
The Cabinetmaker Not the handle. The latch on the door is dirty Jun 13 2018, 11:33 AM
jim_hoyland Loosened and reset the catch on the door jamb, wor... Jun 13 2018, 11:52 AM
jim_hoyland Thanks Tom; Is there a trick to loosening the doo... Jun 13 2018, 01:35 PM
Thanks Tom; Is there a trick to loosening the do... Jun 13 2018, 02:18 PM
jim_hoyland
Thanks Tom; Is there a trick to loosening the d... Jun 13 2018, 03:33 PM
Medtner3
Thanks Tom; Is there a trick to loosening the d... Aug 20 2023, 11:34 AM
Travis Neff Loosen the 6 bolts at the front hinges and move th... Jun 13 2018, 01:40 PM
Larmo63 The inside of the door latches work SO much better... Jun 13 2018, 02:02 PM
mgphoto
The inside of the door latches work SO much bette... Jun 13 2018, 02:37 PM
rhodyguy How hard is it to turn the latching piece by hand? Jun 13 2018, 02:24 PM
Where is the rubber block that should be on the l... Jun 13 2018, 02:30 PM
rhodyguy Right. You captured it while I was editing. Senior... Jun 13 2018, 02:34 PM
cary The latch portion in the door needs a DEEP clean. ... Jun 13 2018, 07:08 PM
Root_Werks
The latch portion in the door needs a DEEP clean.... May 15 2023, 11:45 AM
914sgofast2 I had a similar problem with both of my doors. E... Jun 13 2018, 08:11 PM
Richncherie 72 914 cannot unlock the driver side door with key... Jan 16 2023, 09:32 PM
jim_hoyland Thanks for reminding me ofmy own thread ! May 13 2023, 06:11 AM
TheCabinetmaker There's nothing wrong with the handles, or the... May 14 2023, 08:23 AM
jim_hoyland A trick I used when re-installing the latch at the... May 17 2023, 08:39 AM
dr914@autoatlanta.com remove the catching mechanism and clean it thoroug... May 17 2023, 08:44 AM
bbrock Well, I've been fighting the same problem on m... May 17 2023, 04:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th November 2026 - 06:07 PM |
