| falcor75 |
Jun 17 2018, 12:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
As I experienced a blown hose to my front oil cooler yesterday I'm now quite aware that just the little green oil pressure light isnt enough. I would like to add an audio warning aswell.
Has anyone done this? What parts did you use and how did you connect it? |
| Mikey914 |
Jun 17 2018, 09:09 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Not a bad idea.
Run it off a separate circuit? Or use the same to trigger the audio? |
falcor75 Oilpressure noise warning? Jun 17 2018, 12:56 AM
Cairo94507 Sorry to hear about the oil line. Hopefully no da... Jun 17 2018, 09:28 AM
falcor75 I'm thinking it should be triggered by the oil... Jun 17 2018, 10:29 AM
SirAndy maybe have a 30-60 second delay
Probably too long... Jun 17 2018, 11:28 AM
SirAndy ... just the little green oil pressure light isnt ... Jun 17 2018, 11:26 AM
Maltese Falcon If you can check out the circuit board in the gaug... Jun 17 2018, 12:46 PM
falcor75 I found a kit for a timing module that is adjustab... Jun 17 2018, 12:50 PM
worn
As I experienced a blown hose to my front oil coo... Jun 17 2018, 06:42 PM
ajserrano Here is a solution... :shades2: Jun 17 2018, 08:21 PM
jim_hoyland A VW/Audi chime relay will do the trick. They can ... Jun 17 2018, 08:44 PM
falcor75 I got the kit i linked above and a 90db buzzer tod... Jun 18 2018, 12:25 PM
porschetub
I got the kit i linked above and a 90db buzzer to... Jun 18 2018, 02:44 PM
falcor75
Here is how i'm thinking to solve it, pleas... Jun 19 2018, 12:41 AM
wndsrfr If you're tracking the car, it's hard to h... Jun 19 2018, 04:08 AM
falcor75 Well the buzzer is more of a beeper and a 90 dB be... Jun 19 2018, 02:13 PM
Valy What would you do when you hear the buzzer? Probab... Jun 19 2018, 09:32 PM
DickSteinkamp
What would you do when you hear the buzzer? Proba... Jun 19 2018, 09:46 PM
jd74914
What would you do when you hear the buzzer? Proba... Jun 20 2018, 12:50 AM
falcor75 I'll stick the the plain old beep, adding more... Jun 20 2018, 02:32 AM
falcor75 Ughhhh,...right now it feels like I should have st... Jun 23 2018, 08:53 AM
76-914
Ughhhh,...right now it feels like I should have s... Jun 23 2018, 09:16 AM
Mark Henry I've never seen anything faster than an idiot ... Jun 23 2018, 11:51 AM
brant
I've never seen anything faster than an idiot... Jun 25 2018, 07:24 AM
falcor75
Here's my newly created ding....I feel a we... Jun 25 2018, 12:59 AM
Spoke
Does the pushrod tube need to be replaced you thi... Jun 25 2018, 10:12 PM
falcor75
Does the pushrod tube need to be replaced you th... Jun 25 2018, 10:42 PM
falcor75 I know the lights work I just think they're ug... Jun 25 2018, 01:58 PM
falcor75 https://www.youtube.com/watch?v=VOjawtYuG_Y
Quick... Jul 19 2018, 05:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:28 AM |
