> Oilpressure noise warning?
falcor75
post Jun 17 2018, 12:56 AM
As I experienced a blown hose to my front oil cooler yesterday I'm now quite aware that just the little green oil pressure light isnt enough. I would like to add an audio warning aswell.
Has anyone done this? What parts did you use and how did you connect it?
falcor75
post Jun 18 2018, 12:25 PM
I got the kit i linked above and a 90db buzzer today. Got the kit all soldered up but ran out of time. Will play more with it tomorrow and shoots some pictures.
porschetub
post Jun 18 2018, 02:44 PM
QUOTE(falcor75 @ Jun 19 2018, 06:25 AM) *
I have a 90db buzzer for a handbrake warning plenty loud enough even where it is mounted under the drivers seat.
Jims info was very helpful,now got me thinking about this setup for my 2.2 six,my 89 Golf had this and it saved me an engine when the head gasket blew and filled the sump with coolant.
falcor75   Oilpressure noise warning?   Jun 17 2018, 12:56 AM
Mikey914   Not a bad idea. Run it off a separate circuit? Or...   Jun 17 2018, 09:09 AM
Cairo94507   Sorry to hear about the oil line. Hopefully no da...   Jun 17 2018, 09:28 AM
falcor75   I'm thinking it should be triggered by the oil...   Jun 17 2018, 10:29 AM
SirAndy   maybe have a 30-60 second delay Probably too long...   Jun 17 2018, 11:28 AM
SirAndy   ... just the little green oil pressure light isnt ...   Jun 17 2018, 11:26 AM
Maltese Falcon   If you can check out the circuit board in the gaug...   Jun 17 2018, 12:46 PM
falcor75   I found a kit for a timing module that is adjustab...   Jun 17 2018, 12:50 PM
worn   As I experienced a blown hose to my front oil coo...   Jun 17 2018, 06:42 PM
ajserrano   Here is a solution... :shades2:   Jun 17 2018, 08:21 PM
jim_hoyland   A VW/Audi chime relay will do the trick. They can ...   Jun 17 2018, 08:44 PM
falcor75   I got the kit i linked above and a 90db buzzer tod...   Jun 18 2018, 12:25 PM
porschetub   I got the kit i linked above and a 90db buzzer to...   Jun 18 2018, 02:44 PM
falcor75   Here is how i'm thinking to solve it, pleas...   Jun 19 2018, 12:41 AM
wndsrfr   If you're tracking the car, it's hard to h...   Jun 19 2018, 04:08 AM
falcor75   Well the buzzer is more of a beeper and a 90 dB be...   Jun 19 2018, 02:13 PM
Valy   What would you do when you hear the buzzer? Probab...   Jun 19 2018, 09:32 PM
DickSteinkamp   What would you do when you hear the buzzer? Proba...   Jun 19 2018, 09:46 PM
jd74914   What would you do when you hear the buzzer? Proba...   Jun 20 2018, 12:50 AM
falcor75   I'll stick the the plain old beep, adding more...   Jun 20 2018, 02:32 AM
falcor75   Ughhhh,...right now it feels like I should have st...   Jun 23 2018, 08:53 AM
76-914   Ughhhh,...right now it feels like I should have s...   Jun 23 2018, 09:16 AM
Mark Henry   I've never seen anything faster than an idiot ...   Jun 23 2018, 11:51 AM
brant   I've never seen anything faster than an idiot...   Jun 25 2018, 07:24 AM
falcor75   Here's my newly created ding....I feel a we...   Jun 25 2018, 12:59 AM
Spoke   Does the pushrod tube need to be replaced you thi...   Jun 25 2018, 10:12 PM
falcor75   Does the pushrod tube need to be replaced you th...   Jun 25 2018, 10:42 PM
falcor75   I know the lights work I just think they're ug...   Jun 25 2018, 01:58 PM
falcor75   https://www.youtube.com/watch?v=VOjawtYuG_Y Quick...   Jul 19 2018, 05:30 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:36 AM
