> Oilpressure noise warning?
falcor75
post Jun 17 2018, 12:56 AM
As I experienced a blown hose to my front oil cooler yesterday I'm now quite aware that just the little green oil pressure light isnt enough. I would like to add an audio warning aswell.
Has anyone done this? What parts did you use and how did you connect it?
wndsrfr
post Jun 19 2018, 04:08 AM
If you're tracking the car, it's hard to hear anything over the induction and exhaust...mine's so loud I wear earplugs....a buzzer would never register. I added a bright red warning light up high on the instrument cluster.....look for "shift light" to get an idea....
falcor75   Oilpressure noise warning?   Jun 17 2018, 12:56 AM
Mikey914   Not a bad idea. Run it off a separate circuit? Or...   Jun 17 2018, 09:09 AM
Cairo94507   Sorry to hear about the oil line. Hopefully no da...   Jun 17 2018, 09:28 AM
falcor75   I'm thinking it should be triggered by the oil...   Jun 17 2018, 10:29 AM
SirAndy   maybe have a 30-60 second delay Probably too long...   Jun 17 2018, 11:28 AM
SirAndy   ... just the little green oil pressure light isnt ...   Jun 17 2018, 11:26 AM
Maltese Falcon   If you can check out the circuit board in the gaug...   Jun 17 2018, 12:46 PM
falcor75   I found a kit for a timing module that is adjustab...   Jun 17 2018, 12:50 PM
worn   As I experienced a blown hose to my front oil coo...   Jun 17 2018, 06:42 PM
ajserrano   Here is a solution... :shades2:   Jun 17 2018, 08:21 PM
jim_hoyland   A VW/Audi chime relay will do the trick. They can ...   Jun 17 2018, 08:44 PM
falcor75   I got the kit i linked above and a 90db buzzer tod...   Jun 18 2018, 12:25 PM
porschetub   I got the kit i linked above and a 90db buzzer to...   Jun 18 2018, 02:44 PM
falcor75   Here is how i'm thinking to solve it, pleas...   Jun 19 2018, 12:41 AM
wndsrfr   If you're tracking the car, it's hard to h...   Jun 19 2018, 04:08 AM
falcor75   Well the buzzer is more of a beeper and a 90 dB be...   Jun 19 2018, 02:13 PM
Valy   What would you do when you hear the buzzer? Probab...   Jun 19 2018, 09:32 PM
DickSteinkamp   What would you do when you hear the buzzer? Proba...   Jun 19 2018, 09:46 PM
jd74914   What would you do when you hear the buzzer? Proba...   Jun 20 2018, 12:50 AM
falcor75   I'll stick the the plain old beep, adding more...   Jun 20 2018, 02:32 AM
falcor75   Ughhhh,...right now it feels like I should have st...   Jun 23 2018, 08:53 AM
76-914   Ughhhh,...right now it feels like I should have s...   Jun 23 2018, 09:16 AM
Mark Henry   I've never seen anything faster than an idiot ...   Jun 23 2018, 11:51 AM
brant   I've never seen anything faster than an idiot...   Jun 25 2018, 07:24 AM
falcor75   Here's my newly created ding....I feel a we...   Jun 25 2018, 12:59 AM
Spoke   Does the pushrod tube need to be replaced you thi...   Jun 25 2018, 10:12 PM
falcor75   Does the pushrod tube need to be replaced you th...   Jun 25 2018, 10:42 PM
falcor75   I know the lights work I just think they're ug...   Jun 25 2018, 01:58 PM
falcor75   https://www.youtube.com/watch?v=VOjawtYuG_Y Quick...   Jul 19 2018, 05:30 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:56 AM
