Headlights don't pop up!, Headlights not working - relay? |
Moose01 |
Jun 18 2018, 08:53 AM
Newbie Group: Members Posts: 15 Joined: 14-November 10 From: Houston, Tx Member No.: 12,386 Region Association: None |
Guys,
My headlights are not working, i.e they are not popping up. I have fogs. Would it be the relay? Any ideas before I start pulling relays etc. The fuses are all good! Chris |
toolguy |
Jun 19 2018, 03:41 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Headlight UP function is terminal "K" of the headlight switch [gray wire]. The headlights pop up on position 1 [parking lights] but does not illuminate the bulbs until position 2.
Headlight DOWN is the green/blk wire on terminal 30b As a test if the switch terminal K is bad, try moving the Gray wire from K to terminal 56, which will delay the headlights pop up to when switch is in Position 2. |
Lo-Fi Version | Time is now: 13th June 2024 - 10:54 AM |
