Heater blower, Heater blower |
simonjb |
Jun 20 2018, 07:25 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I’m having a bit of an issue with getting the heater blower to work...
The motor bench tests fine The wire on the heater control lever is connected correctly When I pull the lever back, I can hear the relay clicking in the engine bay However, when I connect the fan to the heater wire the motor does not run. I confirmed that brown connected to brown and green to yellow, just like the picture below. I was holding the motor - so it wasn’t separately grounded - would that be the issue? Any ideas ? |
Steve |
Jun 22 2018, 07:58 AM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Pretty simple circuit to troubleshoot. Lever pulled all the way up, connects relay to ground. Should be 12 volts at relay. Using a digital volt meter or analog meter, check for power and ground at the blower.
Lo-Fi Version | Time is now: 1st June 2024 - 05:51 PM |
