> Door Stop Rebuild, After R&R both doors produce loud clicks upon opening
North Coast Jim
post Apr 19 2018, 05:54 PM
Rebuilt both the door stops with 914 Rubber kits last year. Kits were from a purchase made in early 2017 IIRC, could be earlier. Doors open and close fine BUT both closures produce loud clicks upon closure of the door. Opening of the doors adds a loud pop to the clicks. Both are lubricated but no relief is found.
What I have noticed is the aluminum machined arms received have no vertical grooves where the wheels are to roll. The profile is smooth except for the closure stop points. I've looked at other door closures and this is the only difference I see - they have these vertical grooves.
Anybody else has experience with these closures and can provide some input.
Left an e-mail with Mikey but he must be flying or driving to Hershey.
Mikey914
post Jun 30 2018, 10:51 PM
The rubber man
We actually went through painstaking detail to reproduce these in the same tension as the OEM when new.
Popping from our experience has been two different issues that are related
The 1st is the pin at the frame has some play, the springs at full force will actually pop the arm as the rollers move across the humps. The popping is slow allowing the pin to shift.
Perhaps we should make some new pins too (IMG:style_emoticons/default/biggrin.gif)
I’ll add them to the list.. (IMG:style_emoticons/default/biggrin.gif)
North Coast Jim   Door Stop Rebuild   Apr 19 2018, 05:54 PM
914Sixer   Problem is not the kit. The holes for the rod in ...   Apr 19 2018, 08:55 PM
jcd914   :agree: I don't know anything about the rebui...   Apr 19 2018, 10:00 PM
Rob-O   Somewhat agree with above. The holes on the piece...   Apr 20 2018, 07:39 AM
Mikey914   I can add the serrations, it just adds $25 to...   Apr 20 2018, 09:50 AM
Rob-O   Completely agree, Mark. It’s tough to juggle un...   Apr 20 2018, 11:49 AM
Bartlett 914   I had the same problem. The pin hole on the body o...   Apr 20 2018, 02:16 PM
North Coast Jim   I had the same problem. The pin hole on the body ...   Apr 20 2018, 07:14 PM
raynekat   I have the same problem and rebuilt mine completel...   Jun 28 2018, 11:50 PM
North Coast Jim   I have the same problem and rebuilt mine complete...   Jun 30 2018, 08:34 AM
raynekat   I have the same problem and rebuilt mine complet...   Jun 30 2018, 09:02 PM
n2j2ryan   Have the same problem with mine. Definitely the pi...   Jun 30 2018, 02:45 PM
Mikey914   We actually went through painstaking detail to rep...   Jun 30 2018, 10:51 PM
n2j2ryan   I'll take two pins!   Jul 1 2018, 12:01 AM
raynekat   What I've found in my case is that the very lo...   Aug 13 2018, 12:12 AM
Philip W.   What I've found in my case is that the very l...   Aug 13 2018, 08:25 AM
raynekat   If any of your pins in the door stop assembly look...   Aug 13 2018, 12:40 PM
mepstein   If any of your pins in the door stop assembly loo...   Aug 13 2018, 01:14 PM
raynekat   Attacked my door stops today to rid them of the lo...   Aug 18 2018, 10:58 PM
Rob-O   Awesome!   Aug 19 2018, 06:44 AM
Mikey914   Interesting. We actually machine these parts. The ...   Aug 19 2018, 10:29 AM
Mikey914   Guys I've checked the tolerance on the parts o...   Aug 20 2018, 04:42 PM
restore2seater   So what your saying is you need to manufacture rep...   Aug 20 2018, 06:35 PM
ConeDodger   So what your saying is you need to manufacture re...   Aug 20 2018, 07:03 PM
Mikey914   Well its obvious now that they do wear. Gonna star...   Aug 20 2018, 08:02 PM
Mikey914   Will start a thread   Sep 19 2018, 11:27 PM
restore2seater   Thanks Mark. :)   Sep 20 2018, 09:47 PM
- Lo-Fi Version Time is now: 4th July 2025 - 08:43 AM
