| Jengah |
Jul 1 2018, 11:15 AM
Newbie ![]() Group: Members Posts: 11 Joined: 30-June 18 From: Central Coast, CA Member No.: 22,277 Region Association: Central California |
I've been lurking for a few months here and could use some help/opinions. I've decided my next project will be a 914 with a extra HP, but can't decide on my route. This would just be a weekend car for twisty roads and occasional track days. I'd like it to be functional so I can still take my wife around in it.
I've had a 914 before (back in H.S.) so I know the car and have shadetree mechanic skills that have helped me maintain/DE my previous fun cars (e30M3, e36M3) so I plan on doing all of the work myself. That being said, I don'nt want to make this unneccesarily challenging (some of you guys are way more patient, skilled, and braver than I am). If I go with a Suby motor, I'll do the NA route. I'm considering either an EJ25 or EZ30. So, the Suby engine is most likely going to have more reliability/last long the higher we get up in HP. It also seems to be the less expensive route. However, it is definitly the slower and more complicated route. Does anyone with experience having tried both engines have opinions and advice on which is better or what the pro/cons are? |
| 914forme |
Jul 1 2018, 11:44 AM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
I have had all flavors except a V8.
Large Type - 4 I hade a 2.8L unit for a very short while, never again. Subaru EZ30 use the Microsquirt for the EFI. Go with a Subaru MT5, and build the mount using the basics from the Small Car Specialties mount, it is built to convert Vanagons. And the standard 4 cal. mounts up front. Trans hanger will have to be fabricated. Exhaust will need to be fabricated. Shifting is via Zero Decible motorsports and a pick and pull sorted shifter Hydraulic clutch can be done via a simple brake Kent made or another supplier here on the forum. Cooling system, Renegade Hybrids has a proven kit $$$$, or lots here used the Celica GTS rad off Ebay. New untested RAD option is from a Renault Alpine, only a couple of use looking at using that RAD, I have one at my shipping center, need to bring it home and see how well it works. Axles and Transaxles , I like Subaru Gears stuff, then you just have a bolt in option. Others used dutchman and Subaru trans CV and 914 outers. If you want to just get the mechanicals sorted out, then their is always Renegade Hybrids. Brakes, suspension, wheels, are still Porsche 914 / 911 / 944 / Boxster / 996 / 908 / Ferrari 308 / Alfa GTV, etc.... Some even use them calipers from a 3 series BMW. A turbo Subaru from a WRX is not much more complicated of a swap. And you could use the Megasquirt PNP if you want. Get a donor car if you can from CoParts.com is a great place to find the oh so special wrecked vehicle your looking for. Rear End damage would be the best for your donor. Have fun, start a build thread as it keeps me from actually working on mine (IMG:style_emoticons/default/av-943.gif) |
| Jengah |
Jul 2 2018, 08:45 PM
I have had all flavors except a V8. Large Type - 4 I hade a 2.8L unit for a very short while, never again. Subaru EZ30 use the Microsquirt for the EFI. Go with a Subaru MT5, and build the mount using the basics from the Small Car Specialties mount, it is built to convert Vanagons. And the standard 4 cal. mounts up front. Trans hanger will have to be fabricated. Exhaust will need to be fabricated. Shifting is via Zero Decible motorsports and a pick and pull sorted shifter Hydraulic clutch can be done via a simple brake Kent made or another supplier here on the forum. Cooling system, Renegade Hybrids has a proven kit $$$$, or lots here used the Celica GTS rad off Ebay. New untested RAD option is from a Renault Alpine, only a couple of use looking at using that RAD, I have one at my shipping center, need to bring it home and see how well it works. Axles and Transaxles , I like Subaru Gears stuff, then you just have a bolt in option. Others used dutchman and Subaru trans CV and 914 outers. If you want to just get the mechanicals sorted out, then their is always Renegade Hybrids. Brakes, suspension, wheels, are still Porsche 914 / 911 / 944 / Boxster / 996 / 908 / Ferrari 308 / Alfa GTV, etc.... Some even use them calipers from a 3 series BMW. A turbo Subaru from a WRX is not much more complicated of a swap. And you could use the Megasquirt PNP if you want. Get a donor car if you can from CoParts.com is a great place to find the oh so special wrecked vehicle your looking for. Rear End damage would be the best for your donor. Have fun, start a build thread as it keeps me from actually working on mine (IMG:style_emoticons/default/av-943.gif) Thanks Stephen. This is a wealth of iniformation. What did you mean by "get the mechanicals sorted out"? |
Jengah Big Type IV or Suby Swap - Opinions Please Jul 1 2018, 11:15 AM
Steve I’m not a fan of big 4’s. I had a 2.4 liter b... Jul 1 2018, 11:26 AM
SirAndy Suby all the way, cheaper, more HP from a stock mo... Jul 1 2018, 11:43 AM
ConeDodger
The only downside is the radiator ...
:shades2:
... Jul 1 2018, 06:41 PM
914forme If I where doing it again, I would go LS with a Bo... Jul 1 2018, 11:46 AM
Mueller I'm putting a more or less stock 1.8 /4 back i... Jul 1 2018, 12:00 PM
Porschef Good question, great debate. I think if you can be... Jul 1 2018, 01:07 PM
Mark Henry
Large Type - 4 ... Jul 2 2018, 06:05 PM
Mark Henry dp Jul 2 2018, 06:14 PM
Jengah
Good question, great debate. I think if you can b... Jul 2 2018, 08:48 PM
A&P Mech I have run the stock 2.0l, a subaru EJ253 and ez30... Jul 1 2018, 01:41 PM
Robnxious From what I have been told, the Suby conversion is... Jul 1 2018, 02:53 PM
flmont I ended up going Subie because the Big 4 rebuild ... Jul 1 2018, 04:17 PM
mepstein The nice thing about the suby swaps is that once t... Jul 1 2018, 04:34 PM
Elliot Cannon Large type IV = more cost less work.
Subie = less... Jul 1 2018, 05:28 PM
bandjoey (Ad Copy from Ebay..no affiliation, info only)
13... Jul 1 2018, 06:30 PM
Andyrew
1... Jul 2 2018, 02:00 PM
... Jul 2 2018, 02:17 PM
76-914 I've a 2.0, an EZ-30D and a 327-300. No contes... Jul 2 2018, 01:36 PM
bandjoey 200hp should make the 914 a happy driver car and e... Jul 2 2018, 02:49 PM
BIGKAT_83 I'd vote for the Subaru over any type 4 engine... Jul 2 2018, 03:16 PM
Andyrew
I think if I was doing another conversion I woul... Jul 2 2018, 04:09 PM
Jengah What about opinions on transmissions?
I'm in... Jul 2 2018, 08:55 PM
Chris H. That trans will work fine for a Subaru conversion.... Jul 2 2018, 09:45 PM
Jengah
That trans will work fine for a Subaru conversion... Jul 2 2018, 10:01 PM
thelogo Irreversibly cutting your car up to do a watercool... Jul 3 2018, 01:02 AM
falcor75
Irreversibly cutting your car up to do a watercoo... Jul 3 2018, 02:20 AM
914forme
Irreversibly cutting your car up to do a watercoo... Jul 3 2018, 03:11 PM
Irreversibly cutting your car up to do a waterco... Jul 3 2018, 03:22 PM
thelogo
[quote name='thelogo' post='2625631... Jul 3 2018, 07:29 PM
Mueller
[quote name='thelogo' post='2625631... Jul 3 2018, 07:37 PM
914forme
[quote name='914forme' date='Jul 3 20... Jul 3 2018, 08:31 PM
mgp4591
Irreversibly cutting your car up to do a watercoo... Jul 3 2018, 03:37 PM
thelogo
Irreversibly cutting your car up to do a waterco... Jul 3 2018, 07:35 PM
DaveO90s4 Subie or big type 4?
Neither.
See Marcus' ... Jul 3 2018, 04:46 AM
Mueller
Neither.
See Marcus... Jul 3 2018, 03:11 PM
914forme What I meant was things like suspension , brakes, ... Jul 3 2018, 03:06 PM
Mark Henry What is the cost of a subi conversion? Just like t... Jul 3 2018, 05:00 PM
mgp4591
What is the cost of a subi conversion? Just like ... Jul 3 2018, 06:21 PM
Rand
Why would you NOT want the advantages? Why do all... Jul 3 2018, 05:12 PM
Jonathan Livesay I have a subie conversion with a WRX STI 2.5, and ... Jul 3 2018, 05:27 PM
914forme Mark I will try - low end $200 American dolla... Jul 3 2018, 06:40 PM
mgp4591 If it's a Concours car, there's no reason ... Jul 3 2018, 08:49 PM
thelogo To quote alec baldwin in the cooler
You dont fuck... Jul 3 2018, 10:02 PM
Craigers17 Not sure if anyone has tried this yet, but if we... Jul 4 2018, 02:26 AM
DaveO90s4 I like having the OEM storage space up front
I lik... Jul 4 2018, 03:40 AM
thelogo https://youtu.be/s33dP0ETrCo
Really listen to t... Jul 4 2018, 06:03 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:36 PM |
