| VintageExcellence |
Jul 10 2018, 02:46 PM
Member ![]() ![]() Group: Members Posts: 52 Joined: 27-August 04 From: San Diego, CA Member No.: 2,636 |
What are you guys doing on fuel lines. I am restoring a early 914-6 with the 2 different size plastic fuel lines through the chassis. I pulled the original lines out, one broke from being brittle and the reason I wanted to change them. What options are out there?
I see stainless steel line replacements. Looks like Tangerine has a set for sale. Anything else out there? |
| porschetub |
Jul 10 2018, 05:17 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,176 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I used late VW plastic FI line and ferals then truck metal brake pipe @ the front,EFI hose clamps only,my original plastic hose was as new but heeded the warning from this forum...feel happier I did the replacement.
| Mark Henry |
Jul 10 2018, 10:06 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I used late VW plastic FI line and ferals then truck metal brake pipe @ the front,EFI hose clamps only,my original plastic hose was as new but heeded the warning from this forum...feel happier I did the replacement. If the plastic lines are good I wouldn't worry about it. If damaged, you welded in new floors (welding heat), or you are running high pressure for a front FI pump, then I'd use the SS lines. With a stock location pump these lines are low pressure, only the pump to regulator FI loop is high pressure. The truck brake pipe is OK but it should have a rolled barb, especially for high pressure. FI clamps should be the only type used and SAE 30R9 rated FI fuel hose. I used to say SAE 30R7 hose was OK for all the low pressure sections and carbs, but after some research on hose quality I will now only use SAE 30R9 rated FI fuel hose on all the fuel lines. |
VintageExcellence 914 fuel line options? Jul 10 2018, 02:46 PM
LowBridge I have a set of Tangerine lines in my 75 and they ... Jul 10 2018, 02:53 PM
Mueller http://www.914world.com/bbs2/index.php?showtopic=1... Jul 10 2018, 02:58 PM
ndfrigi
http://www.914world.com/bbs2/index.php?showtopic=... Jul 10 2018, 05:13 PM
BPic
What are you guys doing on fuel lines. I am resto... Jul 10 2018, 03:01 PM
Racer Chris
A 914world member has SS lines as well.
:rol... Jul 11 2018, 05:39 AM
AZBanks
:ro... Jul 11 2018, 10:26 AM
mepstein I have 3 sets of tangerine lines for my cars. Chri... Jul 10 2018, 03:27 PM
914forme Tangerine, and he will also do AN fittings on the ... Jul 10 2018, 05:00 PM
euro911 Either vendor, Tangerine or Robert (Rotary'14)... Jul 11 2018, 01:09 AM
branston Tangerine for me too
Fitted them to my '74 la... Jul 11 2018, 05:24 AM
jfort Second on Tangerine's steel lines. Just instal... Jul 11 2018, 08:46 AM
bbrock This question may be heresy, but are SS lines nece... Jul 11 2018, 09:35 AM
napasteve
This question may be heresy, but are SS lines nec... Jul 11 2018, 09:52 AM
bbrock
This question may be heresy, but are SS lines ne... Jul 11 2018, 05:14 PM
jcd914
[quote name='napasteve' post='2628129' date='Jul ... Jul 11 2018, 05:53 PM
worn I bought ss tubing from JEGS and silver soldered A... Jul 11 2018, 05:59 PM
Coondog :agree: :agree: :agree:
Happy Robert (Rotary 1... Jul 11 2018, 09:56 AM
euro911 Yeah, both guys are great guys.
Chris has a myri... Jul 11 2018, 10:46 AM
Mueller
Chris has a myr... Jul 11 2018, 10:48 AM
phatnine11 Ok, the question is about SS vs mild steel. Most f... Jul 11 2018, 05:30 PM
Mark Henry I did my '67 bug in 3/8" brake line, I ha... Jul 11 2018, 08:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 26th September 2026 - 05:30 AM |
