Lost 2nd and 4th, Tips and suggestions |
Ed_Turbo |
Jul 14 2018, 12:18 PM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
Hey guys,
I went out cruising and ate dinner in the 914. (IMG:style_emoticons/default/driving.gif) Nice drive and dinner until heading home I could not engage 2nd and 4th. Just kept grinding but I managed to work around and skip the gears. Took it back to the garage and check what I found. Looks like the bushings went to valhalla. Worked on other transmission linkage/shifters before so not new to me. I will be ordering a shift bushing kit from Marky Mark. Hopefully it is an easy fix. Anything else I should be aware about with these 901 trannies? -Ed |
76-914 |
Jul 14 2018, 12:49 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Hey guys, I went out cruising and ate dinner in the 914. (IMG:style_emoticons/default/driving.gif) Nice drive and dinner until heading home I could not engage 2nd and 4th. Just kept grinding but I managed to work around and skip the gears. Took it back to the garage and check what I found. Looks like the bushings went to valhalla. Worked on other transmission linkage/shifters before so not new to me. I will be ordering a shift bushing kit from Marky Mark. Hopefully it is an easy fix. Anything else I should be aware about with these 901 trannies? -Ed Might I suggest the brass bushings. $50 and damned well worth it. (IMG:style_emoticons/default/beerchug.gif) |
marksteinhilber |
Jul 14 2018, 01:06 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
Hey guys, I went out cruising and ate dinner in the 914. (IMG:style_emoticons/default/driving.gif) Nice drive and dinner until heading home I could not engage 2nd and 4th. Just kept grinding but I managed to work around and skip the gears. Took it back to the garage and check what I found. Looks like the bushings went to valhalla. Worked on other transmission linkage/shifters before so not new to me. I will be ordering a shift bushing kit from Marky Mark. Hopefully it is an easy fix. Anything else I should be aware about with these 901 trannies? -Ed Might I suggest the brass bushings. $50 and damned well worth it. (IMG:style_emoticons/default/beerchug.gif) I agree. Do all your bushings. Use the oil bronze bushings where they are available. Check all linkages for slop and tighten or replace cone (pointed)set screws. There is a roll pin back near the side shift console on the gear box on the 90 degree elbow or knuckle the I have found very worn and sloppy too. I drilled and threaded in an extra set screw there to remove slop at that roll pin. Helps tighten up the whole shift linkage assembly. Clean, grease, and put covers on to keep grit out of the grease. Good luck! |
Ed_Turbo |
Jul 14 2018, 01:37 PM
[/quote]
Might I suggest the brass bushings. $50 and damned well worth it. (IMG:style_emoticons/default/beerchug.gif) [/quote] I agree. Do all your bushings. Use the oil bronze bushings where they are available. Check all linkages for slop and tighten or replace cone (pointed)set screws. There is a roll pin back near the side shift console on the gear box on the 90 degree elbow or knuckle the I have found very worn and sloppy too. I drilled and threaded in an extra set screw there to remove slop at that roll pin. Helps tighten up the whole shift linkage assembly. Clean, grease, and put covers on to keep grit out of the grease. Good luck! [/quote] Oh yeah, the set screws. Got to check those out see how they are, thanks (IMG:style_emoticons/default/beerchug.gif) Who sells the brass ones? Bruce, hey Bruce where are you? I know you are on your computer. (IMG:style_emoticons/default/laugh.gif) $50 is not that much, but I need to maintain a budget for the interior. I am also starting the Fall semester next month for the Grad program so I need to balance my expenses. -Ed |
Lo-Fi Version | Time is now: 9th June 2024 - 01:39 PM |
