Remote starter button, Can' always rely on the keyswitch |
Kansas 914 |
Jul 17 2018, 11:09 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I want to add a hidden remote starter button. Can I tap into the yellow wire under the passenger seat (used to have the interlock - but all that is bypassed)?
Switch tied to yellow wire and a switched hot? It will still require a key to switch to "ON" position - but I know the keyswitch will fail on me in the middle of the Mojave or someplace similar. Thanks in advance! |
jcd914 |
Jul 17 2018, 01:14 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
O have a big fat power wire from the battery run behind passenger seat where the seat belt interlock used to be. This eventually will be where my mega-squirt control unit lives.
I plan to install and heavy duty relay to operate as the hot start relay does to reduced the load on the ignition switch. I plan to use the yellow wire from the ignition switch to energize the relay and the battery power from the relay to the starter solenoid. Jim |
Kansas 914 |
Jul 17 2018, 01:43 PM
O have a big fat power wire from the battery run behind passenger seat where the seat belt interlock used to be. This eventually will be where my mega-squirt control unit lives. I plan to install and heavy duty relay to operate as the hot start relay does to reduced the load on the ignition switch. I plan to use the yellow wire from the ignition switch to energize the relay and the battery power from the relay to the starter solenoid. Jim Nice - Mega Squirt........... (IMG:style_emoticons/default/drooley.gif) |
Lo-Fi Version | Time is now: 5th June 2024 - 07:42 AM |
