Remote starter button, Can' always rely on the keyswitch |
Kansas 914 |
Jul 17 2018, 11:09 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I want to add a hidden remote starter button. Can I tap into the yellow wire under the passenger seat (used to have the interlock - but all that is bypassed)?
Switch tied to yellow wire and a switched hot? It will still require a key to switch to "ON" position - but I know the keyswitch will fail on me in the middle of the Mojave or someplace similar. Thanks in advance! |
porschetub |
Jul 17 2018, 02:30 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
If you install the Ford relay there should be no need for a separate switch,I had one in a Kombi that I bought because the PO couldn't fit a new switch it was a PITA.
My understanding is by fitting a relay you are removing load from the switch and it merely becomes a device to activate the starter,Mark Henry mentioned less switch issues,makes sense. It not only the plastic that go's on the switch ,the contacts for the start (cranking)function get worn and burnt ,at least one switch problem is gone with the relay. |
Kansas 914 |
Jul 17 2018, 02:42 PM
If you install the Ford relay there should be no need for a separate switch,I had one in a Kombi that I bought because the PO couldn't fit a new switch it was a PITA. My understanding is by fitting a relay you are removing load from the switch and it merely becomes a device to activate the starter,Mark Henry mentioned less switch issues,makes sense. It not only the plastic that go's on the switch ,the contacts for the start (cranking)function get worn and burnt ,at least one switch problem is gone with the relay. Yes - I agree - I have had both contacts and plastics fail on nearly new switches (not German). |
Lo-Fi Version | Time is now: 4th June 2024 - 10:55 PM |
