944 Front brakes .. ? |
Beakster |
Jul 22 2018, 09:40 PM
Member Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None |
Has anyone tried putting a set of 944 front brakes and rotters on a 914 ?? would that work ??
bdstone914 |
Jul 23 2018, 08:46 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Has anyone tried putting a set of 944 front brakes and rotters on a 914 ?? would that work ?? 1st question, Why? Do you need that much more braking? How is the car used ? Street or track? It is a system you are changing and all affected components including struts, hubs, etc. need to be considered. What rear brakes and master cylinder? 2nd question , which 944 brakes ? Are you referring to the 4 piston 944 Turbo Brembo calipers or the steel 944 calipers? Many different sizes of the turbo calipers between front and rear, and year they are from. Yes the turbos calipers can be installed on a 3.5" 911 front end. They are a 3.7" C-C on the bolt holes. They can be milled to fit 3.5. Bruce |
Lo-Fi Version | Time is now: 10th June 2024 - 03:27 PM |
