Front window trim question |
rosenfe |
Jul 21 2018, 06:04 PM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
My trim has come loose on the top at union and at the bottom strip and at 90. I see the tabs the trim fits into.I have crimped them a bit to make a tighter fit,but I may be missing a tab on the bottom of window. Can the tab be replaced with window in?Im assuming there is a hole in body for tab to insert。Is this correct?Anything else I can do to secure trim?Adhesive etc
dr914@autoatlanta.com |
Jul 25 2018, 12:49 PM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
no way without the windshield removed, one should always replace the clips when the windshield is out to make sure that the chrome strips stay in place.
Really the only thing you can do now is put some black silicone under the strip and tape it down until it dries My trim has come loose on the top at union and at the bottom strip and at 90. I see the tabs the trim fits into.I have crimped them a bit to make a tighter fit,but I may be missing a tab on the bottom of window. Can the tab be replaced with window in?Im assuming there is a hole in body for tab to insert。Is this correct?Anything else I can do to secure trim?Adhesive etc |
Lo-Fi Version | Time is now: 10th June 2024 - 05:07 AM |
