gfg3 |
Never Too Old ![]() ![]() Group: Members Posts: 117 Joined: 5-January 15 From: Southern Virginia Member No.: 18,295 Region Association: None ![]() |
Have all four of my Fuchs alloys off the car for some brake work Decided to clean the inside of the wheels while they were off. Outsides look great. Got a lot of the brake dust/grime off the insides with Dawn detergent and a scrubby but I'm left with tons of black speckles. Anyone have a way to bring the insides of the wheels back to close to original? I didn't want to get too aggressive with the cleaners. Thanks.
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,533 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
sithot |
Member ![]() ![]() Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None ![]() ![]() |
Did not take picture of inside of rims, you can see a little. But used the some process on the inside fender wells. Mark ![]() ![]() I have a 3,000 PSI hot water (makes it's own) pressure washer that when equipped with a 0º head will cut lumber. It will also remove paint and anything else in the way. (IMG:style_emoticons/default/headbang.gif) Backing off to 15º - 25º makes it very manageable. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,321 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Did not take picture of inside of rims, you can see a little. But used the some process on the inside fender wells. Mark I have a 3,000 PSI hot water (makes it's own) pressure washer that when equipped with a 0º head will cut lumber. It will also remove paint and anything else in the way. (IMG:style_emoticons/default/headbang.gif) Backing off to 15º - 25º makes it very manageable. We have one at the shop. Diesel powered. Does an awesome job, especially cleaning engines and trans. Gets in all the nooks and crannies and the hot water melts off the tar. No scrubbing needed. |
Lo-Fi Version | Time is now: 13th June 2024 - 08:09 PM |
