> *N00b* Car Won’t Start
brianp626
post Jul 29 2018, 10:19 AM
Hi all, new here needing a little help. Let me give you a quick backstory. Picked this car up on Friday. It’s a 73 1.7. Against my better judgement I decided to drive the car home, it started up fine, ran fine. 30 minutes into my commute it’s smoking BAD. Have it towed home. After looking around for a problem I noticed it was missing a hose from the flashback valve (?) to the passenger side head and was pretty oily in that area so assumed it was spitting oil on top of the engine hence the smoke. Replaced the hose. Went to fire it up and it won’t start. Engine oil level seems fine so it didn’t lose much. Any ideas why this would start fine before the incident and now it won’t? Thanks for the help in advance.
falcor75
post Jul 29 2018, 12:40 PM
Is the fuel pump in the stock location underneath front of the engine? Might be vapor locked? Or if the alternator isnt charging the battery you might have drained it enough so it doesnt have enough ooomph to start..... check the voltage while cranking.
brianp626   *N00b* Car Won’t Start   Jul 29 2018, 10:19 AM
Spoke   :wttc: Does the engine try at all to start? You ...   Jul 29 2018, 10:35 AM
brianp626   Thanks Spoke! It turns over but there isn’t ...   Jul 29 2018, 10:44 AM
taylspin46   Thanks Spoke! It turns over but there isn’t...   Jul 29 2018, 10:55 AM
The Cabinetmaker   Do you hear the fuel pump prime for half a second ...   Jul 29 2018, 10:47 AM
brianp626   Fuel pump does prime. Looked around the area of th...   Jul 29 2018, 11:57 AM
taylspin46   Fuel pump does prime. Looked around the area of t...   Jul 29 2018, 12:26 PM
falcor75   Is the fuel pump in the stock location underneath ...   Jul 29 2018, 12:40 PM
Coondog   Reset points, clean and lube rotor shaft   Jul 29 2018, 12:51 PM
brianp626   Taylspin- CHT looks fine. Falcor- I believe it is...   Jul 29 2018, 12:57 PM
falcor75   Vapor locks go away by letting the car cool down, ...   Jul 29 2018, 01:41 PM
Dave_Darling   The engine needs three things to run: Fuel, air, ...   Jul 29 2018, 02:09 PM
Rand   Smells funny to me. I get something can go wrong ...   Jul 29 2018, 02:53 PM
brianp626   **Update** sprayed some starter fluid in the intak...   Jul 31 2018, 05:58 PM
Spoke   If you haven't done a tune-up on your new car,...   Aug 1 2018, 05:21 PM
brianp626   Yea, I’m thinking about taking it to a local Vol...   Aug 1 2018, 05:33 PM
BeatNavy   Not sure what that is in the bottom picture, but t...   Aug 1 2018, 06:07 PM
brianp626   but the top picture is one of the lines that goes...   Aug 1 2018, 07:19 PM
76-914   Could these be the hoses from the charcoal filter ...   Aug 1 2018, 08:01 PM
brianp626   Could these be the hoses from the charcoal filter...   Aug 1 2018, 08:06 PM
Dave_Darling   One of those hoses goes from the fan shroud to the...   Aug 1 2018, 09:58 PM
brianp626   One of those hoses goes from the fan shroud to th...   Aug 3 2018, 11:13 AM
brianp626   I started the car when I got home from work yester...   Aug 3 2018, 11:17 AM
Dave_Darling   The other hose doesn't go to the throttle body...   Aug 3 2018, 01:02 PM
76-914   What is the ohm reading on the CHT sender when it ...   Aug 3 2018, 05:18 PM
brianp626   What is the ohm reading on the CHT sender when it...   Aug 6 2018, 08:48 PM
brianp626   **BUMP** Update, car starts now. Will run and driv...   Sep 15 2018, 03:02 PM
- Lo-Fi Version Time is now: 18th July 2026 - 10:03 AM
